Help! Engine lopes after Head Gasket replaced.
I just replaced the head gasket on my 85-22-REC engine. And now my engine lopes or modualtes engine speed up and down when I accelerate and hold position. EFI was working fine when torn down. Anyone got any suggestions? I have checked my vacuum lines and there doesn't seem to be any gasket leaks.
Thanks,RWade |
Check the ECU for codes. Sounds like something awry in the EFI. Read this link if you need help with that.
http://www.off-road.com/toyota/tech/codes/ |
Originally Posted by rwade
(Post 50500432)
Thanks,RWade |
The idle is fine. Just when I accelerate or open throttle and hold it pulses.
RWade |
Thanks MudHippy,
I will try the diagnostic code and see what I find. Rwade |
Hey, I unplugged the wires to the throttle position sensor and the engine runs great.
RWade |
By the way the diagnostic check only gave me 1 code which I believe that means everything is OK
RWade |
(Post 50502466)
RWade First make sure the throttle is fully returning to closed position. If not, fix that. If it is, and problem is still present, adjust the TPS. |
