Help! Engine lopes after Head Gasket replaced.
Old Apr 13, 2007 | 12:22 PM
rwade's Avatar
Question Help! Engine lopes after Head Gasket replaced.
I just replaced the head gasket on my 85-22-REC engine. And now my engine lopes or modualtes engine speed up and down when I accelerate and hold position. EFI was working fine when torn down. Anyone got any suggestions? I have checked my vacuum lines and there doesn't seem to be any gasket leaks.
Thanks,RWade
Old Apr 13, 2007 | 04:16 PM
MudHippy's Avatar
Check the ECU for codes. Sounds like something awry in the EFI. Read this link if you need help with that.
http://www.off-road.com/toyota/tech/codes/
Old Apr 13, 2007 | 05:02 PM
rdharper's Avatar
Thanks,RWade
How is the idle?
Old Apr 14, 2007 | 07:14 AM
rwade's Avatar
The idle is fine. Just when I accelerate or open throttle and hold it pulses.
RWade
Old Apr 14, 2007 | 07:20 AM
rwade's Avatar
Thanks MudHippy,
I will try the diagnostic code and see what I find.
Rwade
Old Apr 16, 2007 | 09:51 AM
rwade's Avatar
Hey, I unplugged the wires to the throttle position sensor and the engine runs great.
RWade
Old Apr 16, 2007 | 09:53 AM
rwade's Avatar
By the way the diagnostic check only gave me 1 code which I believe that means everything is OK
RWade
Old Apr 19, 2007 | 10:58 AM
rdharper's Avatar
RWade
Ok.. this means the TPS is not adjusted correctly, or the throttle is not fully returning to the closed position.. dirt, or binding, or throttle dashpot is preventing full return. One of those will be the problem.
First make sure the throttle is fully returning to closed position. If not, fix that. If it is, and problem is still present, adjust the TPS.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
Colington
Mar 8, 2020 09:51 AM
smiley52
Jul 11, 2015 05:16 AM
87blyota
Jul 10, 2015 04:31 AM
