84 4runner not starting
I have a 84 4 runner with a 22r and its not starting turns over but won't fire getting spark and fuel to the Carb and help would be great thanks
Did it run while you owned it and then one day didn't start? Or has it never run while in your possession? Have you tried spraying carb cleaner down the air intake and then try starting it? If it does not try to start, you can likely eliminate fuel issues as the culprit.
Yea it ran when I got it running one day then went to go out wheeling with a buddy and all it would do is turn over I have gas in my Carb and the spark plugs are wet I think I've got it narrowed down to electrical issues
I think they just went through this a few weeks ago. Dizzy cap and rotor have to be new to work. Water vapor gets in there and inhibits spark. Spray some silicone spray on wires as well.
Have you done a compression test? If not...I would start there. If you have low/uneven compression... thats your problem. If compression turns out fine, at least you know you have a healthy motor....
Checked it out its timed right cause I retimed it and I still am only getting spark to the number one cylinder I have new plugs wires pick up coil new coil and igniter rotor cap still no start this is bad
JaredL
06-16-2015 04:47 PM
