My sub box is stuffed with something?
I bought a 10" JL Audio WO already in a box specially made for the sub. I opened it up a few minutes ago and the box has a bunch of stuffing of some sort inside of it. It's white and kinda looks like cotton. Should I take that out or leave it in? Thanks.
Sorry I laughed!
I robbed this from a page so dont tell anyone.
Polyfill is basically fiberglass, like the pink insulation stuff. There are variations of polyfill, like "Polyfil", that can be found in arts & crafts stores. "Polyfil" will work almost as well as fiberglass, but without the nasty problems you run into when working with the pink stuff. By using polyfill in a sub box, it will artificially make the box act larger than it is, which will improve the deep bass response. Note that actually making the box larger than the driver is designed for will make it sound like crap. The speaker manufacturer or distributor will be able to tell you how much you should use. Otherwise, the only way to find out is by trying it yourself. Add about 1/2 pound at a time, until you like what you hear. When using polyfill, try to spread it out evenly, and try to make sure it doesn't touch the driver. If you are using a ported box, then only line the sides of the box with a 1" thick sheet of polyfill. You can buy polyfill that comes in sheets or loose.
do you know the airspace your sub is rated for?......the polyfill slows the wave down like mentioned earlier. It is all the same stuff....if you know the cubic air space needed for the sub then I'd seal it up with the correct air space. Sealed with the right airspace should give a harder hit.....I think the ported and band pass box(half sealed space and in front of speaker half ported) gives more of a deep rumble. I don't know a ton, but picked up stuff from the brother in law. He was a big Car toys employee back in the day. Just my thoughts hope it helps
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 05:51 PM
