Transfer case ???s
Transfer case ???s
I have an 83 SR5 toyota 4x4. Got the motor in it, running great. I put a w56 tranny 5 speed tranny behind the carburated 22r. I plan on buying the dual adapter kit for the transfer case. I am going to order it tomorrow, My question is... I have 3 transfer cases not sure what years they came off of but all in good working order, I know they are all gear driven but but how do I tell if they are 21 spline or 23 spline. What do I need to know before I order the dual adapter? Tanks guys...
- http://www.marlincrawler.com/tech/gu...1-gear-install
Depends if you are adding 4.7 gears at the same time you build duals, then you want to get a 23 spline dual case adapter with 23 spline 4.7 gears (stronger).
Sure you got a W series and not a G. Your front tcase will need to match your tranny for forward or top shift and the rear case has to be a top shift.
Need a dual case adapter and any other goodies, hit me up, I'll help you out.
Good luck.
Good luck.
Good luck.
Good luck.
Simple, just count the splines on the input shafts:
Hmm thats something to think about. But I already have the steel to build my crossmember and do my driveline work. I work at a machine shop as a machinist, so the tools and materials are easy to come by. I just dont want to have to do my drivelines twice this way I can go to 4.70 gears later on and not have any issues with the driveline. I ave been waiting on building my driveline and crossmember because I put a w56 tranny in it and its a bit longer than the stock tranny. So building new drivelines and crossmember is a must anyhow. Thanks for the input, much appreciated. Sounds like next pay day it will be 4.70 gears or armor one or the two...
I got a second tcase with my 4runner, and plan on going the dual case route down the road. Decided to go with the 4.7 gears first, less down time in the end. Install the 4.7 gears in the spare tcase, swap the cases and its back on the road. If it wasn't my daily driver, the extra down time wouldn't be a issue.
But in your case, if you have to redo the shafts anyways, then dual cases now might be the way to go. More gearing options And if you can do the work your self, the price isn't as bad.
dude count them like . . . . 1111---222222222---3333333 44444444. . . .and you will know when you stop at either 21 or 24 ???? huh better get another beer and try agian
I agree with you that the stock crossmember sucks, I had ran dual cases with the stock crossmember for close to 6 months before i upgraded to a buper beef one........?
Off subject here. What if you run dual cases with 21 spline? Is it IMEDIATELY going to fail at rear output? I have the dual adapter with 21 spline and 4.7 in the rear case. Please tell me i didnt just waste my money with the 21 spline.
I have duals with 21 spline stuff. Its been fine for 2 years.
23 spline makes sense if you are doing it all at once. I started with 4.7's and to mate to my W56, I had to run 21 spline. Then, when I went duals, I didn't want to redo the input on the rear case, so I went with a 21 spline adapter.
I'd imagine the failure rate is much higher with V-6's and V-8's, especially when coupled to quite large tires. With a 4cyl, and smaller tires, I've found that breakage is much less common.
You should be fine, but if you ever plan on going any larger than a 35" tire (even with 35's I'd recommend it though...) you're going to need to regear your differentials to something lower than the stock 4.10. Gearing properly to match your tire size relieves stress on your drivetrain so breaking parts will happen less often...ie driveshafts, output shafts in your t-case etc...I'm not saying that if you don't you're gunna break left and right, there will just be a greater chance of you breaking.
I have 5.29s on the way. I also have 36in Iroks ready to be mounted and installed. I'm not going to bash it on the trails too hard to begin with.
Another question.....has anyone used the chromoly birfields, not the whole kit, just the birfields. I plan on running ARB up front. Just want to know if i need the whole axle shafts or just the chromoly birfs.
Save up the extra $100 or so and do the whole thing. All you will do is move the weak point from the birfield joint to the necked down outer end of the inner shaft.
You want the 30 spline Longfields, then you'll never have to worry about it.
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Phantez
09-30-2015 08:24 AM
Toys4parts
09-26-2015 01:56 PM
