Turbo 4runner start up, almost done
#341
For some reason I was thinking the water/meth referenced boost pre-throttlebody.
#342
Well my truck is down right now so might be better off just PM'ing me any questions you have or better yet post a thread and I will post in there. I much prefer to help people in threads for the most part as it leaves the info around for others to use.
#344
Buying a kit? Building your own? Running washer fluid, straight methanol?
#347
Definitely building a kit. Probably a simple setup with a boost pressure switch. No plans for straight methanol yet. I need to work on my valve body before I go straight meth and crank up the boost. I just want to be able to run 7-8psi without worrying about EGTs. I'm staying at 5psi until I get a wideband. I'll update my build thread https://www.yotatech.com/forums/f2/v...-setup-274414/ when I make any changes.
#348
#349
That will be the problem. I'll have to try to find a drum somewhere because I live 30 miles from anywhere rural Arkansas. Windshield washer fluid or water will be much easier to come by.
/edit: it appear my "local" race track is one of two places in Arkansas to get methanol.
#350
