| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
Randy 2006 Sequoia 1985 4Runner: Build-up has begun Build-up Thread: http://www.yotatech.com/showthread.php?t=80743 www.tornadoalleycruisers.com TLCA #12443 Last edited by Ranski; 04-24-2004 at 09:56 PM. |
#2 (permalink) |
Do you mean a driveshaft U-joint?
__________________
1995 4Runner V6 4x4 |
#3 (permalink) |
im getting my rear drive shaft u joint done as we speak. i JUST dropped it off at Drive Line Service here in Cali.
My truck would make clunk clunk clunk noises as i drove so i dropped the drive shaft (2 piece) and brought it in. They are going to replace my center carrier and the u joints that is on the front of the rear half of the rear drive shaft (the side that connects to the center carrier). Also, they are going to extend my drive shaft a bit b/c the prev owner, when lifting the truck 4" didnt have the drive shaft extended. So out the door: $260 I dunno how easy it is to replace u-joints, but my friend who's a gear head, told me to just take it in and get it done right.
__________________
2003 4Runner Limited 4wd V8. Bone stock except for the Nitto All Terrains. My Rig 91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. My Rig |
#4 (permalink) |
same idea for front axle joints or driveshaft:
a press is very handy for this job, but it can be done with a C clamp and the right size socket - I think I saw a press at Harbor Freight. Can also be done by hammering the bejesus out of the yokes but it's time consuming and noisy! Essentially you press the cap out of one side (into a big enough socket) while pressing the cap into the opposite side - end result is both caps are out of the yoke. Do this twice per yoke.
__________________
2000 SR5 4WD elbow, ISR mods; Mobil1 5W-30 with Toy filter; Amsoil air filter all hail hypnotoad |
#5 (permalink) |
Guest
If you did it yourself may have only cost $50 to $100 for parts. Doing U joints is pretty easy. The hardest part is getting ahold of a C clamp & greese gun. Other than that its an easy fix.
#6 (permalink) |
IHMO.. if youcan find the right shop, it may onlycost $10 or $20 to get them to put it in the shaft.. The toyota uses a joint that must be pressed on all 4 sides and they are a pain in the .... I broke my dad's vice trying to press mine out and paid a shop $10.. Yep, $10 to install my shaft I brought in with my u-joint.. (They have since done my Jeep's front axle shafts for the same price. Now a 2 cap press out, I would do at home. But the 4 cap press outs can be a pain. Ask around first..
__________________
#7 (permalink) |
Thanks for all the input guys. If I can truely find a shop to do it for $10 then I will probably head that direction. However, I'm always inclinded to do it myself at least once, so come the time on the trail that I need to do it, I will have already been through it once in a controlled environment.
__________________
Randy 2006 Sequoia 1985 4Runner: Build-up has begun Build-up Thread: http://www.yotatech.com/showthread.php?t=80743 www.tornadoalleycruisers.com TLCA #12443 |
#8 (permalink) | |
Quote:
BTW Let me know if you need any help with that repair.
__________________
Sebastian 97 LX450 01 4Runner (FOR SALE - link): 285 Revos/16x7 OEM alu 4.56, r-ARB OME882/N91SC, OME890/N86C, RB dif drop, Lars' discos, front-end-links-in-the-rear, SS bump stops and Panhard drop, InlandTrucks A-arms, MasterCraft limiting straps ARB f-bumper, SS r-bumper, moded Carnage skids, moded RB RockSliderZ 1" RB BL, A/T cooler & filter, steering cooler, s-steel brake lines, AMSOil air filter, Mobil1 oils and filters, 12K e-MileMarker |
| Tags |
| 1988, 1996, 4runner, 4x4, costs, dealer, install, joint, joints, price, repair, replace, replacing, toyota, ujoints |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to replace upper ball joint | Localmotion | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 02-04-2007 06:46 PM |
| replace rear diff or rear axle... in a bind | old 86 | 86-95 Trucks & 4Runners | 6 | 11-11-2006 10:20 AM |
| Ball joint replace | RustBucket | 86-95 Trucks & 4Runners | 8 | 05-26-2006 12:24 AM |
| Rear axle bearing.. To replace or not? | r854rnr | General Vehicle Related Topics (Non Year Related) | 12 | 03-13-2006 06:14 PM |
| Clicking CV joint, repack or replace? | TStango | Maintenance & Repair Archives | 2 | 04-22-2005 08:36 AM |
