Is this the daytime running light switch? *pic*
Old Aug 11, 2008 | 11:28 AM
Mason Dixon's Avatar
I need to disable the daytime running lights, does this have to be unplugged?
Old Aug 11, 2008 | 11:44 AM
pfdaxe's Avatar
Take a chance and un-plug it
But yes....that is it......
Old Aug 11, 2008 | 01:22 PM
jmt83's Avatar
That is it. Unplug it and no more DRLs. I recently plugged mine back in because when I hooked up my PIAA driving lights they did not behave properly with it unplugged. Anyone have any ideas/knowledge about this?
Mason Dixon, where in Huntsville are you?
Old Aug 11, 2008 | 01:31 PM
My drl's are affecting a new dvd/stereo headunit, so this should fix it thanks guys!
JMT83, I'm actually in Madison, you?
Old Aug 11, 2008 | 02:22 PM
jmt83's Avatar
I'm off Providence Main Street.
I'm going to be upgrading my head unit soon, how are the DRLs affecting yours?
Old Aug 11, 2008 | 04:04 PM
Turns out its not my drl's...... its a funny little wiring problem tho that i'm trying to straighten out, guess i gotta call the manufacturer.
Old Aug 12, 2008 | 04:50 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
My plug for the DRL's are in between the battery and the fender. It's a gray connector. I had mine unplugged a few years back with no problems but ended up plugging them back in.
Old Feb 16, 2009 | 03:02 AM
chuckdeez's Avatar
i recently installed a hi/lo hid kit on my 2000 4runner. i'm not sure if all the kits are the same but the way mine wires in it plugs into the factory headlight harness on the dr/batt side and then runs from that side to the pass side headlamp leaving the pass side headlamp harness unplugged. i tried unplugging the resistor box, tried removing the drl fuse, and still the drl's remain on. what other options do i have? anyone else had this problem or know how to solve it? i really want to stay away from cutting wires.
Old Feb 16, 2009 | 07:49 AM
y2kltdsport's Avatar
the drl box on my 2000 ltd is on the batt side between the bat and on fender simply unplug it
Old Feb 16, 2009 | 10:16 AM
chuckdeez's Avatar
yea i tried unplugging that box and it didnt help i think it is becuase of the hi/lo hid kit i installed.the way mine wires in it plugs into the factory headlight harness on the dr/batt side and then runs from that side to the pass side headlamp leaving the pass side headlamp harness unplugged. not sure why this would matter but unplugging that box has no effect. there is a seperate relay that wires in with the hid kit because of the plunging bulb that adjusts where the light goes when you put the high beams on.
Jun 1, 2021 01:51 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
dandownunder
23
Jun 25, 2002 07:00 AM
