4wd Problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-29-2009, 05:25 PM   #1 (permalink)
4wd Problem
I need help. I have a 98 Toyota T100 5speed 4wd. I wanted to know if any of you can send me the wiring diagram and let me know which vaccum tube plugs to which outlet. Thanks.
matchu808 is offline
Old 07-29-2009, 09:38 PM   #2 (permalink)
4Crawler's Avatar
This is for the earlier trucks, but may be close:
- http://www.off-road.com/toyota/tech/add
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-29-2009, 09:39 PM   #3 (permalink)
camo31"10.50"'s Avatar
hahaha do away with it..and go with some Lock-Out hubs..lol
sorry no help on the diagram..maybe Google it..lol
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE
1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous
"Its still a toyota man.. Dont deprive it of its capabilities.."
"If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009
camo31"10.50" is online now
Old 07-30-2009, 01:41 PM   #4 (permalink)
thanks...lock-out hubs?
Old 07-30-2009, 01:50 PM   #5 (permalink)
4Crawler's Avatar
Quote:
a.k.a. manual hubs:
- http://www.off-road.com/offroad/arti....jsp?id=399668
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-30-2009, 04:12 PM   #6 (permalink)
does anyone have a toyota t100 4wd? if so can you take some pictures of the vacuum hoses that run to the differential so I can see how it is installed. Thanks
Old 07-31-2009, 08:02 PM   #7 (permalink)
Froggy93's Avatar
I can try t get a pic of mine tomorrow but it is a 93. notsure if it is the same but it may help.
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals
17" Powder coated Sequoia wheels
32" Mickey Thompson Baja ATZ tires stock lift
new factory clutch- if you order from Downey, make sure you get the right one:(
diff breather mod.
cobra cb
custom rear bumper w/tire carrier-Kennasaw Mtn. acc.
In the works. light bar and hella 500's
Froggy93 is offline
Old 08-03-2009, 09:55 AM   #8 (permalink)
yeah please if you can email it to me or pm or just post it on this thread. it should be the same if it is automatic locking hubs.
Old 08-03-2009, 05:17 PM   #9 (permalink)
is it hard to install lock-out hubs?
Old 08-03-2009, 05:37 PM   #10 (permalink)
Tragic Drive's Avatar
Do you need a picture of the axle vacuum lines or the VSV's
__________________
,Thomas
Supercharged 3.4 in a ARB Locked 95 Runner
Tragic Drive is offline
Old 08-04-2009, 05:14 AM   #11 (permalink)
topdown4runner's Avatar
Location: Somewhere between Disney World & Daytona Beach
Not hard.
You just need to be sure & get ALL the hardware from the donor truck. All the washers, lock rings, etc...
Also go ahead and get the 10mm bolts , washers & cone washers that came from the donar. The Hex bolts that came on my '95 T100 suck.
I changed mine out & it was not hard.
You will also need a large ( I think 32mm ) socket. I know someone sells the kit, but I cannot think of it at this time.
I made my own before I saw them for sale.
FYI,
you may need to double check if you can reasonably change to lock out hubs on the '98. If memory serves, the easy change out stopped at '95. The '96 & up are a Pain in the Ars & really Expen$ive !
Good Luck to you!
topdown4runner is offline
Old 08-04-2009, 10:36 AM   #12 (permalink)
Tragic Drive-I need a picture of the axle vacuum, the solenoids, and the egr box. I want to see how it is hooked up so I can hook up my ADD again. My friend and I took it off thinking we wouldn't need it, but stupid me, come to find out those were the ones powering the front diff. Basically I have the solenoids in place and the egr box, but I don't know where all the vacuum hoses go.
Old 08-04-2009, 02:54 PM   #13 (permalink)
This is from a 96 T100 that my friend owns. I dont have any pics of the diff. However its only 2 lines if I remember right.
Good Luck.
[IMG][/IMG]
__________________
,Thomas
Old 08-06-2009, 10:59 PM   #14 (permalink)
Do you need more pics other than what has already been posted?
I have my 97 all stock and can take pis of the diff area for you.
On Aisin manual hubs they are fine to install. You need to have a good size brass punch and you can resuse the cone washers that are on the existing drive flange. The T-100 has its disconnect at the Diff so the hubs are relatively simple. I can take them on and off in 10min as long as the cone washers aren't horribly frozen.
__________________
97 T-100 SR5 4x4
5spd Ext Cab 100k and counting Forest Green metallic
Aisin Hubs
Flannelman is offline
Old 08-10-2009, 06:54 PM   #15 (permalink)
that would be great. acutally i need to know which tube goes to which solinoid...and the whole set up. So if you can take picture of the box on the driver side with the solinoid and the diff that would be great. thanks for the help
Old 08-17-2009, 08:49 AM   #16 (permalink)
jrohland's Avatar
Service manual do?
The '97 I just got came with the Toyota factory service manual. I will try to look in that is see if the diagram is in there.
jrohland
jrohland is offline
Old 08-19-2009, 04:13 PM   #17 (permalink)
thanks for all the help guys
Tags
22r, 4wd, 95, add, engine, forum, hawaii, ifs, oahu, problem, remanufactured, set, solenoid, t100, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
