93-98 T100s All T100 trucks
4wd Problem
Old Jul 29, 2009 | 04:25 PM
matchu808's Avatar
4wd Problem
I need help. I have a 98 Toyota T100 5speed 4wd. I wanted to know if any of you can send me the wiring diagram and let me know which vaccum tube plugs to which outlet. Thanks.
Old Jul 29, 2009 | 08:38 PM
4Crawler's Avatar
This is for the earlier trucks, but may be close:
- http://www.off-road.com/toyota/tech/add
Old Jul 29, 2009 | 08:39 PM
camo31_10.50's Avatar
hahaha do away with it..and go with some Lock-Out hubs..lol
sorry no help on the diagram..maybe Google it..lol
Old Jul 30, 2009 | 12:41 PM
matchu808's Avatar
thanks...lock-out hubs?
Old Jul 30, 2009 | 12:50 PM
4Crawler's Avatar
a.k.a. manual hubs:
- http://www.off-road.com/offroad/arti....jsp?id=399668
Old Jul 30, 2009 | 03:12 PM
matchu808's Avatar
does anyone have a toyota t100 4wd? if so can you take some pictures of the vacuum hoses that run to the differential so I can see how it is installed. Thanks
Old Jul 31, 2009 | 07:02 PM
Froggy93's Avatar
I can try t get a pic of mine tomorrow but it is a 93. notsure if it is the same but it may help.
Old Aug 3, 2009 | 08:55 AM
matchu808's Avatar
yeah please if you can email it to me or pm or just post it on this thread. it should be the same if it is automatic locking hubs.
Old Aug 3, 2009 | 04:17 PM
matchu808's Avatar
is it hard to install lock-out hubs?
Old Aug 3, 2009 | 04:37 PM
Tragic Drive's Avatar
Do you need a picture of the axle vacuum lines or the VSV's
Old Aug 4, 2009 | 04:14 AM
topdown4runner's Avatar
From: Somewhere between Disney World & Daytona Beach
Not hard.
You just need to be sure & get ALL the hardware from the donor truck. All the washers, lock rings, etc...
Also go ahead and get the 10mm bolts , washers & cone washers that came from the donar. The Hex bolts that came on my '95 T100 suck.
I changed mine out & it was not hard.
You will also need a large ( I think 32mm ) socket. I know someone sells the kit, but I cannot think of it at this time.
I made my own before I saw them for sale.
FYI,
you may need to double check if you can reasonably change to lock out hubs on the '98. If memory serves, the easy change out stopped at '95. The '96 & up are a Pain in the Ars & really Expen$ive !
Good Luck to you!
Old Aug 4, 2009 | 09:36 AM
matchu808's Avatar
Tragic Drive-I need a picture of the axle vacuum, the solenoids, and the egr box. I want to see how it is hooked up so I can hook up my ADD again. My friend and I took it off thinking we wouldn't need it, but stupid me, come to find out those were the ones powering the front diff. Basically I have the solenoids in place and the egr box, but I don't know where all the vacuum hoses go.
Old Aug 4, 2009 | 01:54 PM
This is from a 96 T100 that my friend owns. I dont have any pics of the diff. However its only 2 lines if I remember right.
Good Luck.
[IMG][/IMG]
Old Aug 6, 2009 | 09:59 PM
Flannelman's Avatar
Do you need more pics other than what has already been posted?
I have my 97 all stock and can take pis of the diff area for you.
On Aisin manual hubs they are fine to install. You need to have a good size brass punch and you can resuse the cone washers that are on the existing drive flange. The T-100 has its disconnect at the Diff so the hubs are relatively simple. I can take them on and off in 10min as long as the cone washers aren't horribly frozen.
Old Aug 10, 2009 | 05:54 PM
matchu808's Avatar
that would be great. acutally i need to know which tube goes to which solinoid...and the whole set up. So if you can take picture of the box on the driver side with the solinoid and the diff that would be great. thanks for the help
Old Aug 17, 2009 | 07:49 AM
jrohland's Avatar
Service manual do?
The '97 I just got came with the Toyota factory service manual. I will try to look in that is see if the diagram is in there.
jrohland
Old Aug 19, 2009 | 03:13 PM
matchu808's Avatar
thanks for all the help guys
djpg2000
Nov 11, 2020 04:56 AM
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
