Daytime running lights
The headlight circuit wiring between a Tacoma that has Daytime Running Lights and one that does not is not even close to being similiar. If your truck has a factory DRL system, you can't disconnect it. To start with the coil side of the main headlight relay goes to ground through the Main Daytime Running Light Relay.
If you pull the 7.5 a DRL fuse you disable the coil side of Day Time Running Light Relay #4, but your headlights won't work at all, because the contact side of this relay allows current from the high and low beam headlights to flow to ground.
Having said that I have to ask the question :- Why would you want to disable the DRL system?
It's a safety system like airbags and seatbelts...would you want to disable those?
Almost all of the studies done around the world indicate that DRL's reduce the number of multiple vehicle daytime crashes.
Check out the link below.
http://www.iihs.org/research/qanda/drl.aspx
Some army bases require drl's to be disabled on vehicles on base,not sure why. On my 02 corolla I had to pull a wire from the drl relay and isolate it which disabled them. Do a search on Google for Toyota daytime running light disable there is TSB for dealers out there.
Not sure if you found it but here's a link to a procedure for 4runner. https://www.yotatech.com/~corey/tech..._drl/ducky.htm
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
09-04-2015 09:27 AM
Johntom240
7
07-13-2015 12:18 AM
madxman21
07-09-2015 10:26 AM
