Dual case & center console?
Those with first gen 4runners....
I'm looking for ideas to retain the console and rear window switches with my dual cases. I was going to move the switches to above the radio, but I'd rather not have to lengthen out the wiring so I figured I'd see what others have done. Any and all ideas welcome.......
There are 3 console switches:
1. Rear window up/down.
2. Rear window lock.
3. Rear wiper.
The rear window lock button is the most ridiculous switch ever, all it does is lock the switch that is right next to it, so I said good-bye to that; you have two switches left. In the summer with the top off, you are not going to need either of the other two buttons, and when the top is on, you might rarely use the rear wiper. My rear wiper didn't even work right, and I have tinted windows, so it's not like I can clearly see out the window anyways; good-bye to that switch. Any finally, my rear defroster doesn't work, and again, it's tinted, so I can't really see through it anyways. So, I took out the defroster switch and put the up/down button there. I then wired the up/down button to the harness in back so that it's perma-hot. Now, you have no console buttons to worry about.
I mean, I don't have dual t-cases, but that shows how I got rid of the switches.
3. Rear wiper.
Thanks all so far, and please keep the ideas/pics coming...
DC,
Do you have any pics? Did you put them up by the clutch cancel one or somewhere else? I didn't really think to put them up there since it didn't seem like there was enough wire but I confess.....it was late and after a few
DC,
That's what I thought, until I tore apart the harness last night and found the gazzillion blue wires that were headed to the back out of one of the connectors. Perhaps I'll just have to take another look at it tonight a little earlier in the evening. I actually already had put the switches in the two open spots above the radio expecting to just pull the harness out from under the seat and tuck it up under the dash.
OK, so here's what my harness looks like connecting to the switches in the center console.
Perhaps they are run differently in different years, because there is no way that there is enough wire to make it up to the radio area. Also, below is a picture of the wiring connector for the window lock switch. Can someone help me out in figuring out how to bypass this?
I appreciate any help that y'all could provide as I'm no wiring master!
3. Rear wiper.
3. Rear wiper.
Jcrawl94
10
10-24-2015 04:34 PM
priest16
15
08-06-2015 07:43 AM
terminator
07-27-2015 07:13 PM
HookahRoo
07-20-2015 07:06 PM
