transfer case grind??
Old 11-07-2006, 05:41 AM
943kgt's Avatar
i've got a 95 22re 4wd and when i go from 2h to 4h it grinds unless i'm to a complete stop? am i doing something wrong here
Old 11-07-2006, 05:43 AM
mastacox's Avatar
Do you have ADD? If not, I'm pretty sure you have to completely stop to shift. Auto or manual transmission?
Old 11-07-2006, 05:45 AM
943kgt's Avatar
manual,
Old 11-07-2006, 05:50 AM
all_terrain17's Avatar
Yes, that's the way it's supposed to function. V6's with the chain drive transfer cases and ADD were able to be shifted at speed, but 4cyl gear drive cases must be shifted from a complete stop (or below 5mph IIRC).
The sunvisor and owners maunal both have transfer shifting instructions...
Old 11-07-2006, 05:51 AM
943kgt's Avatar
ok cool, i still feel a slight grind at 5 mph but i'm not even gonna try it from now on unless i'm at a dead stop. thanks everyone
Old 11-07-2006, 06:25 AM
943kgt's Avatar
how detrimental to the transfercase do you think that grinding was? it only happend a few times, once really bad at about 15-20 ish? i didnt force it i just touched it and immediatly backed off
Old 11-07-2006, 06:26 AM
mastacox's Avatar
You're fine, just a little noise that let you know to back off.
Old 11-07-2006, 07:23 AM
rngrchad's Avatar
I have to come to a complete stop, or my tacoma xfer case acts like it wants to explode. About every shift lever xfer case except jeeps, I've found will grind unless your at a complete stop....
Old 11-07-2006, 07:25 AM
943kgt's Avatar
thats kinda funny because i'm use to my dads jeep cheerokee. tahts y i tried to put it in 4h while in motion, call me retarded but thats the only 4wd vehicle i've ever driven
Old 11-07-2006, 07:27 AM
4Crawler's Avatar
That t-case in not syncromesh, so you either must be stopped for the gears to line up or if you have the front hubs locked (assuming the same size front and rear tires and same axle ratios) you can shift between 2H and 4H at most any speed, since the front driveshaft keeps the front drive gears spinning in sync with the rest of the t-case.
Old 11-07-2006, 07:31 AM
4runnermt's Avatar
I have a '94 4cyl manual trans 4runner with ADD, and I can shift in and out of 4wd while moving without any noise whatsoever. I've shifted into 4hi going about 30mph a lot of times without any problems. The owners manual says I can shift in or out of 4hi at any speed under 55? I think.
Old 11-07-2006, 07:35 AM
4Crawler's Avatar
Yes, if you have ADD, then the t-case is synchromesh into 4H, so that when you pull the shift lever back, the synchro rings spin up the front drivetrain before pushing the front axle disconnect in to lock the driver's side axle into place.
Old 11-07-2006, 02:33 PM
943kgt's Avatar
i can go from 4h to 2h without a problem in motion, but id imagine thats normal, and theres no directions on my visors nor do i have a manual, so thanks for the info guys
Old 11-07-2006, 02:42 PM
4Crawler's Avatar
Sure, in 4H, you have the whole case moving, front and rear drive section, so they are synchronized. Shift into 2H and you just move the FWD section out of engagement, nothing has to mesh up so unless it is bound up, it should shift 4H to 2H w/o problems. It is when you have the FWD gears sitting still and the RWD gears spinning that you run into problems. Either slow down to a slow enough speed where the gears can mesh up or lock the front axle to keep the FWD gears spinning so they will mesh up.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
viesail
09-21-2015 06:00 AM
TransAmBandit
09-20-2015 06:08 PM
an1mal_69
09-08-2015 09:40 AM
eggens
09-05-2015 12:16 AM
Quick Reply: transfer case grind??
