Pulling a 3.0
Old Mar 12, 2006 | 06:17 PM
jjenks0's Avatar
Pulling a 3.0
I need to do some work on my 3.0, replace seals do the valves, new clutch. Is it a good idea to pull of the intake before it is pulled? What else removed while it is in the engine compartment makes the job go easier?
Old Mar 12, 2006 | 06:21 PM
callmej75's Avatar
Nah you could leave the intake on. Just take everything off the front of the motor and fan shroud and you have enough room easily to pull it. Make sure when ya unbolt the a/c compressor to strap it up out of the way so the motor doesn't hang up on it when you are moving things forward. Unbolt the exhaust from the drivers side and let er' rip!
Old Mar 12, 2006 | 10:17 PM
chopps's Avatar
Take the intake off. you will need to do this anyway to get the harness loose from the engine.
Old Mar 12, 2006 | 10:19 PM
chopps's Avatar
If you were just taking the engine out I would say to disconnect the wiring harness form the computer.
Old Mar 13, 2006 | 03:40 AM
callmej75's Avatar
Is he referring to the plenum or WHOLe intake? If so I misread it...yes take the plenum off to disconnect the harness and drape it over the front of the truck
Old Mar 13, 2006 | 04:10 AM
jjenks0's Avatar
Whats the plenum?
Old Mar 13, 2006 | 04:16 AM
callmej75's Avatar
Originally Posted by jjenks0
Whats the plenum?
Old Mar 13, 2006 | 12:45 PM
jjenks0's Avatar
Oh I see. Great picture thanks.
Old Mar 13, 2006 | 01:13 PM
snap-on's Avatar
the lower plentum (the thing right below the yellow part above) is at the centerline of the motor. I made a jig out of angle iron to bolt to the top to lift the motor with. allows you to use a engine leveler correctly to tilt the engine if your pulling it with the trans attached.
else have fun trying to get those bell houseing bolts off!
Old Mar 13, 2006 | 01:49 PM
jjenks0's Avatar
sounds fun. what size are bolts holding the angle iron on?
Old Mar 13, 2006 | 02:19 PM
jjenks0's Avatar
I need to put in a new clutch and shifter bushing so I reckon I will pull it all at once.
tobylab
Jan 18, 2016 07:06 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
Gone Fission
Jul 24, 2015 12:49 PM
ZONAYODA
Jul 13, 2015 07:17 PM
tobylab
Jul 12, 2015 12:53 PM
