Play in steering.
Old 06-25-2014, 03:09 PM
iamwieb's Avatar
Play in steering.
95 pickup and I'm just checking on the play in my steering and diagnosing a few rough spots in suspension and what not. Took a video with my truck on a jack and wiggled the tires. It looks like there is a bit of play in the ball joints. Is this normal or do I need new ball joints. If that's what they're even called.
Old 06-25-2014, 03:22 PM
scope103's Avatar
Yeah, your phone is shaking a lot. Other than that, I can't tell anything from the video.
If you're worried about sloppy steering, you should check that. http://personal.utulsa.edu/~nathan-b.../3onvehicl.pdf
If you're worried about ball joints, you should check them. http://personal.utulsa.edu/~nathan-b...28balljoin.pdf
Good luck!
Old 06-25-2014, 03:29 PM
iamwieb's Avatar
Yeah sorry bout the movement with the phone. It just seems when I move my tires side to side with it jacked up on both sides, there is like an inch of movement in all those little joints.
Old 06-25-2014, 03:47 PM
millball's Avatar
Any and all of those points that show substantial movement, are worn out, and should be changed.
zytra
01-24-2019 03:16 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
rmill05
09-27-2015 01:43 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Play in steering.
