Official 86-95 FAQ READ FIRST!
Old 06-14-2010, 09:58 AM
Staff
DeathCougar's Avatar
In this sticky, you will find all the info you need regarding Lifts, Tires, Lockers, Manual Hub conversions, Performance upgrades, etc etc.
Check this thread first, and if you cannot find info in here OR via the search function, THEN you should create a new thread.
Manual Hub Conversion info:
https://www.yotatech.com/forums/f116...ild-up-158644/
https://www.yotatech.com/forums/f116...ebuild-157649/
ADD System info:
http://www.off-road.com/trucks-4x4/t...tem-19259.html
Lift Info:
90-95 4Runners
https://www.yotatech.com/forums/f116...-guide-155339/
86-95 Trucks, 86-89 4Runners Leaf Spring type suspension
https://www.yotatech.com/forums/f116...-first-201994/
Tire info:
https://www.yotatech.com/forums/f177...thread-169234/
Gearing, axle code info, general gear FAQ:
https://www.yotatech.com/forums/f116...osting-204178/
89-95 SR5 Cluster Swap:
https://www.yotatech.com/forums/f116...w-pics-179106/
More to be added as time goes on.
DeathCougar is offline
Old 06-14-2010, 03:59 PM
Staff
What kind of Toyota do I have:
4Runners:
1st GEN: 1984-1989
2nd GEN: 1990-1995
3rd GEN: 1996-2002
4th GEN: 2003-current
Pickups:
1st GEN: 1964-1968 (Stout)
2nd GEN: 1969-1974 (Hilux)
3rd GEN: 1975-1978
4th GEN: 1979-1983
5th GEN: 1984-1988
6th GEN: 1989-1995
7th GEN: 1995 1/2-current (Tacoma)
Deckplate Mod:
https://www.yotatech.com/~corey/tech.../deckplate.htm
http://www.wattora.com/mods/deckplate/
http://www.top4runners.com/ja/perf.html#deckplate
https://www.yotatech.com/forums/show...&highlight=ISR
ISR:
3.0- https://www.yotatech.com/~corey/tech/blu_intake/blu.htm
3.4- https://www.yotatech.com/~corey/tech...r/96runner.htm
https://www.yotatech.com/~corey/tech...take/albpm.htm
Extended Diff Breather:
https://www.yotatech.com/~corey/tech...r/breather.htm
How much lift do I need for x tires:
For the IFS Toyota pickups and 4Runners ('86-'95) the following tire/lift combinations apply:
31x10.50-will fit fine, no mods
32x11.50-should fit, may require minor adjustments
33x9.50/10.50-may fit w/ no lift on stock wheels w/ minor fender trimming and torsion bar adjustment
33x12.50-on 15x8/4.75" backspace wheels needs 1" body lift, and front torsion bar lift (1"-2") or 1.5" ball joint spacer and some sort of rear suspension lift (such as longer spring shackles or a coil spring spacer) to level the truck, plus some fender trimming. Here is a picture of this combination showing the minor front fender trimming needed to fit the tires. Conventional wisdom suggests a full 4" IFS lift for this wheel/tire combination, but using a combination of milder lift components will produce the same end result that will function as well if not better than the taller all-in-one lift kit and at less cost. And in case you think this won't work, take a look at this very combination in action in 4x4Wire's Hot Toys write-up on Don West's '94 pickup.
35x12.50 on 15x8 w/ 3.75" backspace wheels needs 4" IFS suspension lift plus 2" body lift for good fit. Many IFS lifts require less backspacing on the wheels to clear the dropped A-arms, this in turn pushes the wheels/tires out farther from the body, making tire/body contact more of an issue. The 2" body lift can help reduce rubbing. Less lift may be possible with more fender trimming. (from 4crawler.com)
For Tacomas and could work with 3rd gen Runners:
http://www.4crawler.com/4x4/ForSale/...ireChart.shtml
Extending Brake lines:
Toyota Fittings are 10mm x 1.00 thread with an inverted flare.
ProComp #7210 are Longer than stock Stainless Steel brake lines. (set of three)
One piece 23" long replacement brake line for the front is Napa #38688
This turns out to be a front line from a 90-96 Nissan 300ZX if you wanna get one from somewhere else.
The flexible rear brake line (goes from the hardline to the rear axle) is commonly used for extending the front and rear brakes lines since it has one male end and one female end. So when these lines are swapped inline with the stock lines, and you will have plenty of room for extra lift and flexy suspensions. The Napa #38256 is the stock length (19" long) rear flexible brake hose. Napa #36881 is 11" long if you need one a bit shorter.
Or you can buy a second stock brakeline and and use the 2 together for the extra length, Napa # 38796.
Balljoint Spacers:
https://www.yotatech.com/forums/show...90&postcount=1
https://www.yotatech.com/forums/show...ljoint+spacers
http://www.4crawler.com/4x4/ForSale/...ml#Description
http://sdori.com/Products.html
https://www.yotatech.com/forums/f116...riteup-201297/
Coils vs T-bar IFS:
Torsion bar crank:
http://www.off-road.com/trucks-4x4/t...ent-19258.html
TRD/Tundra lift for 3rd gen 4Runner:
https://www.yotatech.com/forums/show...t=longer+shock
Shocks for lifted Toyotas:
Lockers:
https://www.yotatech.com/forums/f31/locker-faq-43572/
https://www.yotatech.com/forums/show...4&page=1&pp=20
https://www.yotatech.com/forums/show...hlight=lockers
Suspension Lift info:
https://www.yotatech.com/forums/f31/suspension-lift-faq-44741/
https://www.yotatech.com/~corey/arti...suspension.htm
http://www.customtacos.com/tech/inde...v2&id=137&c=10
Elocker "grey wire mod" all range mod-
http://www.hboss.net/4runner/locker_safety.htm
Manual hub swap:
Aisins: https://www.yotatech.com/~corey/tech...etal22lica.htm
Warns: https://www.yotatech.com/~corey/tech.../matt_hubs.htm
Off road tires:
https://www.yotatech.com/forums/show...&highlight=SAS
SAS:
http://www.tacomaterritory.com/forum...splay.php?f=36
http://www.sonoransteel.com/SA_Parts.html
Tech articles:
https://www.yotatech.com/~corey/tech/techpage.htm ((Old one, not updated anymore))
https://www.yotatech.com/forums/f125/ ((New one in the forum format))
Air Filters (K&N, Amsoil etc.)
https://www.yotatech.com/forums/show...ighlight=K%26N
Pirate 4x4 Toyota FAQ Tons of Information :
http://www.pirate4x4.com/forum/showthread.php?t=173918
http://www.pirate4x4.com/forum/showt...hreadid=110627
That's it for me for now this much searching is hurting my brain...Post up with things I forgot I'll be back later to add more.
The following users liked this post:
hurricanes (07-03-2023)
crammit442
7
11-29-2017 12:30 PM
BeMiceElf
10-10-2015 09:40 PM
trailgoat
08-13-2015 05:54 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: Official 86-95 FAQ READ FIRST!
