1985 Waggy 44 - If money were no object, how would you build it?
Old May 25, 2005 | 07:08 PM
ravencr's Avatar
Hey guys,
If money were no object and I had a Dana 44 front axle to be used for my SAS, how would you build it up? What axles? Basically, what parts would you buy to build it up as the ultimate Dana 44 front end? I know that I want a ARB front locker and Dana equivalent(close) to 5.29 gears, and other than that, I've done very little research on the subject, so this is my initial starting point. I'm thinking about gradually building the axle up till it's ready to go, and then perform my SAS, probably either a spring over axle or might possibly a coilover front suspension. It's all up in the air right now.
Chris
Old May 25, 2005 | 08:12 PM
kyle_22r's Avatar
if money was no option, i'd build a ford 9" with dana 60 knuckles
however with a 44, i'd start with an ARB and 5.13 or 5.38 gears(no 5.29 for dana axles), CTM u-joints and superior shafts. warn hubs are a good investment here, unlike on a toy axle.
building slowly is definitely a good idea. get everything done right and having it the way you want rather than building it fast and tearing it apart a few times and spending a lot more money in the end...
Old May 25, 2005 | 08:50 PM
phorunninduke's Avatar
I like your thinking Kyle
Old May 25, 2005 | 09:02 PM
sschaefer3's Avatar
CTM U-Joints and Superior Evolution series Cro-Mo axles like I have.
$1100 right there alone.
Old May 25, 2005 | 09:44 PM
Albuquerque Jim's Avatar
Just use Schaefer's parts list
Old May 26, 2005 | 02:15 AM
ravencr's Avatar
Ok, so here's the recommended list so far:
1) ARB front locker
2) 5.38 Ring & Pinion
3) CTM U-Joints
4) Superior Evolution Series Cro-mo Axles
5) Warn Hubs
Ok, is that all I need to do to an old axle to make it perfect? What about bracing and rock protection?
Chris
Old May 26, 2005 | 02:42 AM
redplastic2p3t's Avatar
1) ARB front locker
3) CTM U-Joints
5) Warn Hubs
Chris
get ahold of joe darlington, he knows what to do, id be doing the same thing that he did to his rodeo
Old May 26, 2005 | 03:58 AM
ravencr's Avatar
He doesn't have CTM's or cro-mo axles, so I'll definitely talk to him, but I think Steve has the most modified front axle I'ev heard about yet!
Chris
Old May 26, 2005 | 03:59 AM
bamachem's Avatar
http://www.sonoransteel.com/SA_Parts.html
Old May 26, 2005 | 04:10 AM
ravencr's Avatar
Originally Posted by bamachem
The list just for the axle will keep me busy for quite some time! Damn! Hey Steve, after do all that just to the axle, is there anything, anything at all you would change if you had it to do over again?
Chris
Old May 26, 2005 | 04:13 AM
bamachem's Avatar
He already swapped over to the CTM u-joints and Superior axles and then also changed the steering shaft to a modified FJ-62 shaft. Those changes are included in the list.
Old May 26, 2005 | 04:23 AM
ravencr's Avatar
What did you mean with this?
Chris
Old May 26, 2005 | 04:40 AM
bamachem's Avatar
those are the things (that i know of) that he changed after the SAS.
Old May 26, 2005 | 04:48 AM
ravencr's Avatar
Ah, gotcha! Do you think with his setup I can run 37" tires without worying about breaking?
Chris
Old May 26, 2005 | 04:52 AM
bamachem's Avatar
the superior axles are the schiznit according to steve - as in NEVER breaking them w/ his 315's. the toyota rear axles are a little beefier than the front stock D44's, and he doesn't think he'll have any problems w/ them. since he thinks this setup is about as close to indestructable as you can get w/ 35's on a 3rd gen, you'd probally still be "safe" w/ 37's considering where you wheel and your skill level w/ a wrench. however, w/ 37's and 5.29's, that thing might be a DOG on the street and not be geared low enough for serious wheeling. better plan on a twin-stick for sure. you do have a DD, don't you? what about a tow rig?
Old May 26, 2005 | 05:10 AM
ravencr's Avatar
It's definitely not my daily driver, that's for sure. As far as a tow rig I don't have one, but I will drive it on my smaller tires and install the larger tires when I get there.
Chris
Old May 26, 2005 | 05:34 AM
sschaefer3's Avatar
I have the Warn Diff Cover Skid Plate, which is the only thing I would change. After dealing with MAD4WD in Ohio, Jason tipped me off to the Rockcrusher diff covers they carry.
That is the one and only upgrade I may do someday, so far everything is doing fine.
Plan on a good $300-400 for all the Timken brearings and seals as well as new ball joints, which are a super pain to change, so plan on paying to have that done.
Old May 26, 2005 | 05:38 AM
sschaefer3's Avatar
Here you go....................
Large image so you can read the words.
Old May 26, 2005 | 05:44 AM
ravencr's Avatar
Thanks Steve! If you were going to piece this together over time, what order would you recommend doing it in?
Chris
Old May 26, 2005 | 05:47 AM
sschaefer3's Avatar
Bearings and seals first along with cleaning up the axle, rebuilt it to new condition. Figure out your steering and if you will change the knuckles.
Then gears and locker
Finally axles and U-Joints.
Three equal cost points.
