Obd1 17 pin to obd2 16 pin adapter question
Ok. Quick question
I have a bluetooth obd2 scanner
which works fine with newer cars using my android phone via bluetooth
my question is. If I buy this adapter
to connect it to my 87 22re pickup diagnostic plug, will it read anything?
thanks in advance
thanks in advance
No, the OBD1 port on our trucks IS a data port, it just requires some fancy footwork to read it. Fortunately, one of our members (RJR) has already done that: https://www.yotatech.com/forums/f116...reader-278801/
If you shop around for awhile on Ebay, you can get one with suitable cartridges and adapters for a couple hundred bucks. I run several different make pre-1997 non-standardised OBD cars and I don't know what I'd do without my old 'brick'.
They cost a bundle, back in the day.
It not only can read the codes, but the software contains a database of what the codes mean.
It may be true that the earlier OBD1 ECMs can give less info than the newest OBD1 ECMs can. I seem to remember differences between what can be got from my '87 and what can be got from my '95 truck.
I even read the TPS output on my '95 Runner and adjusted the TPS using my scanner.
It's not cheap
http://www.ebay.com/itm/Snap-On-MT2500-Scanner-With-Manuals-Extras-Original-Hard-Case-Good-Cond-/111579766840?hash=item19faac2038&item=111579766840&pt=Motors_Automotive_Tools&vxp=mtr
You don't need a $2,000 (or a coupla hundred) scanner. All you need is a $6 multimeter (you have that already) and the manual (here you go, for free: http://personal.utulsa.edu/~nathan-b...34electron.pdf)
A scanner is nice, mostly because you already have it and know how to use it. But for me, I'm not going to spend even a coupla hundred bucks on a "magic box." I would prefer to know just what signal I'm reading and what it really represents.
Plus, I'm cheap.
It's really nice when you take a road test and can watch the scanner data in real world driving conditions. It paid for itself many times over. But like I said, if you work in a shop it's a good investment. I sold my Scanner and bought a cheap $20 code reader because I'm retired and have no use for it now. The MT2500 also had the code diagnostic procedure, no FSM needed.
rjtrials
08-06-2015 07:25 PM
TJWilly
07-31-2015 02:05 PM
crashburnoveride
07-10-2015 06:39 AM
