ISR done. Is this ok?
Old 03-16-2011, 06:07 PM
suprathepeg's Avatar
So the ISR is done, gonna start plumbing the snorkel in the next few days.
So far I'm noticing much better throttle response and better acceleration but this engine is begging for air more then most.
Is this alright? Do I need the PAIR or can I just delete it all together? If I do delete what if anything happens?
Old 03-17-2011, 01:00 PM
anyone?
Old 03-17-2011, 01:08 PM
totally a bro
Staff
vital22re's Avatar
looks okay. I'm not sure on the pair valve. But I would tie it back in. Whats with the canister on the breather hoses?
Old 03-17-2011, 01:20 PM
Canisters are filters, they keep the oil from building up in the intake and they work I've had them on for about 3 years and my intake is clean and dry.
Without the resonator the PAIR is super noisy and I like having the added space under the hood so if I can get away without it I'd like to.
Old 03-17-2011, 07:28 PM
Tubbyfatty's Avatar
I hope that isnt the spectre plastic intake....in a few months that will become very brittle and crack, then a piece can get sucked in to your throttle body and hold the butterfly wide open, ask me how i know....
Id just go to lowes/homedepot and get a 45* elbow of grey PVC.
Old 03-17-2011, 08:23 PM
its aluminum.
Old 03-17-2011, 08:45 PM
Tubbyfatty's Avatar
I hope it is, and not the plastic coated with shiny stuff that makes it look like aluminum....lol. Just trying to save you what I went through.
Old 03-17-2011, 11:27 PM
baddest94's Avatar
What happened to your spectre plastic 45? I just dun the supra afm swap on my truck and used one i dont want ne probs
Old 03-18-2011, 06:30 AM
Wrenchinjoe's Avatar
You can remove the PAIR valve, here is a thread that discusses it:
https://www.yotatech.com/forums/f116...emoval-202562/
If you choose not to remove it, I have also seen folks put one of those mini filters where you have blocked it with a bolt.
I ran a section of radiator hose from the air cleaner bib to that fitting, thereby deleting the resonator, and it looks factory.
Old 03-18-2011, 07:23 AM
Tubbyfatty's Avatar
It worked great for about 2 months, but all the heat cycles it went through it got really brittle and cracked one day. I didnt notice is because one of the rubber couplers was covering it and driving home from work one night, a piece got sucked in to the throttle body and jammed the throttle open. I didnt notice till I went to shift and when I pushed the clutch in the engine hit 6k before i reached for the key.
So now I use some gray PVC pipe from lowes, 3'' around, 45* elbow, $5
Old 03-18-2011, 07:59 AM
baddest94's Avatar
Thanks man ill have to change that id hate for that to happen. Ima try and find a metal one i like the chrome look. Thanks for the info
ashamsuddin
17
01-13-2023 03:17 AM
83
18
09-21-2015 06:15 PM
Kytowboater
09-17-2015 11:17 AM
Boomer8404
09-17-2015 07:59 AM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: ISR done. Is this ok?
