Doug thorley header problem!!
Old 12-17-2012, 07:08 PM
bensyota's Avatar
I have installed the headers. Problem is the original crush nut used off the bottom of egr piping is not working with the crush sleeve that was supplied with the kit. It seems like the crush nut is not deep enough to grab threading off bottom of egr. The supplied crush nut works fine on the header threading. I'm stuck. The Crush sleeve doesn't even fit into the threading of egr or top of header. The copper piping fit together fine, I'm just having problems with the egr connection. I am also upset that dthorley cannot make a flex piping as well for the pair reed valve so that it can fasten to its original position. Can someone please help me with my problem
Old 12-17-2012, 07:15 PM
snap-on's Avatar
cant help, but NWOR and Downey dont have good solutions either.
(I still have my truck with NWOR, i sold my 4runner that i put downey headers on)
Old 12-18-2012, 12:42 AM
wyoming9's Avatar
Red face
Figure out what size you do need and make it or find it else where.
All kinds of neat things out there if you look around.
All sorts of industrial suppliers .
I would say the reason the proper pieces are not included is because it would raise the price so much these headers would not sell as well.
Old 12-18-2012, 03:57 AM
92 TOY's Avatar
OK...go here ------>>> https://www.yotatech.com/forums/f199...0/index49.html
I'm kinda thinking you are having the same issue we did....or not. I can't remember any details really but I'm gonna read it just like you should. start with POST #1218
yup...looks like I explain it all between that post and #1229
hopefully, this helps and is the same deal. sounds like it.
Old 12-18-2012, 09:25 AM
SkiRig's Avatar
From what I remember one side (probably the header side) uses the supplied Thorely crush part, the top connection uses the stock crush piece.
edoyle12
11
03-20-2017 02:26 AM
RatOmeter
10-22-2015 03:17 PM
tj884Rdlx
08-28-2015 12:04 PM
clok
08-01-2015 09:42 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Doug thorley header problem!!
