Busted antenna?
Old 01-13-2016, 01:53 PM
Chris Parker's Avatar
Busted antenna?
Floppy antenna on a 93 pickup, pulled the inner fender liner and found a PVC tube clamped into place, which looks like it's supposed to be attached to the antenna base.... But it's not.
I guess my question is, what exactly is wrong with this picture? Busted? Missing part?
Thanks
Old 01-13-2016, 01:54 PM
Not sure why it wouldn't let me post both pictures...
Old 01-13-2016, 02:07 PM
Staff
Terrys87's Avatar
Your antenna tube has broken. I cut the head off of a bolt and splice it back together.
From my 88 Thread >>> https://www.yotatech.com/forums/f199...l#post51740271
Old 01-13-2016, 02:11 PM
Awesome, thanks!
The ground wire, is that supposed to be attached to the metal base?
Old 01-13-2016, 02:23 PM
Staff
Terrys87's Avatar
I am at work right now, but I should be able to get you a picture of it tomorrow. I forget where it actually hooks up to.
If you look at trucks several trucks and see the antenna is tilted back, it is that shaft that is broken. You can get another one from the boneyard and it will most likely break later on. The bolt trick has yet to fail me. I dont recall the size bolt I use, but I get one that is just a hair larger then the plastic tube and thread it into the tube.
I have bought broken antennas from salvage yards and they nearly give it to you cause it is broken. The threaded bolt trick makes it better then new.
Old 01-14-2016, 04:44 AM
Staff
Terrys87's Avatar
Here is an electric antenna but same principal, not sure where the ground actually connects to but maybe the picture will help.
Old 01-18-2016, 05:53 PM
Got it fixed using the bolt trick, I just left the small (ground?) wire off and the radio works fine.
Thanks guys
Old 01-19-2016, 03:46 PM
jeremyt's Avatar
I have now ripped off 3 antennas. Been thinking, there has to be a shorter, rubber or generally flexible replacement option for those of us pushing through branches and such often?
Old 01-20-2016, 11:26 AM
RJR
RJR's Avatar
My retractable antenna was shot and all busted up inside. I bought a generic flexible antenna from Autozone and was able to friction fit it into the mount on the fender. Works great, and flexes whenever it needs to. It's the black antenna with a spiral wire around it. I pulled the old motor out so I don't have to listen to it wheezing every time I start the truck.
That was 5 years ago and I haven't had to give the antenna a thought since.
Old 01-22-2016, 11:58 AM
RAD4Runner's Avatar
Deleted Whip Antenna
I deleted whip antenna and replaced it with hidden one sandwiched between top-liner and Fiberglas cap.
This method will only work with Fiberglas roof.
Posted here.
4x4-runner
08-17-2020 01:52 PM
pdyebrasil
11-21-2015 08:56 PM
Steven.m.paulk
11-13-2015 08:57 PM
Jeff Parker
11-05-2015 05:16 PM
CajunFisherman
10-17-2015 06:12 PM
Quick Reply: Busted antenna?
