Brake Fluid Sensor wiring
Old 11-06-2013, 10:26 AM
Woogies's Avatar
Another master cylinder related question. As far as I know brake fluid level sensors were standard equipment on all 1994 pickup models. My appears to be missing, I suspect the previous owners. I found clipped wires on the drivers side and I'm thinking it may be it and I was hoping somebody can confirm.
I was going to simply short them out to see if the brake light went on, but I'm hesitant. I don't want to cause any additional problems.
Old 11-06-2013, 10:32 AM
oldblue's Avatar
the wiring diagram shows a white with black tracer wire and a gray with white tracer wire.
Old 11-06-2013, 10:35 AM
Woogies's Avatar
I have no other loose wires in the engine compartment, I don't think they would have yanked it either...
The wires in the picture are white/black and green/white
Old 11-06-2013, 10:41 AM
oldblue's Avatar
ooops, yeah its a green wire. it says g/b, i thought it was grey, but green it is.
Old 11-06-2013, 12:25 PM
scope103's Avatar
Doesn't look like a Toyota Reservoir on the Master Cylinder either.
Old 11-06-2013, 02:46 PM
Gamefreakgc's Avatar
I know that some 95's do not have the sensor wire. I was just working on my brother's 4Runner this past weekend (bone stock, only 90k miles in great shape) and I noticed there is no sensor or float in the brake fluid reservoir and no wires.
The previous owner may have purchased a new reservoir that had wires when none were necessary. Or, they might have yanked the wires if there was a malfunction, say the brake light wouldn't turn off.
My question is... if it doesn't light up, who cares? Unless you're losing brake fluid, which then implies a bigger question of, what is leaking?
sandyota
02-04-2021 11:16 AM
Eggslinger
06-08-2019 03:32 PM
88yodabasket
07-13-2015 01:32 PM
Johntom240
7
07-13-2015 12:18 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Brake Fluid Sensor wiring
