Brake Fluid Sensor wiring
Another master cylinder related question. As far as I know brake fluid level sensors were standard equipment on all 1994 pickup models. My appears to be missing, I suspect the previous owners. I found clipped wires on the drivers side and I'm thinking it may be it and I was hoping somebody can confirm.
I was going to simply short them out to see if the brake light went on, but I'm hesitant. I don't want to cause any additional problems. http://s16.postimg.org/42e9pvd7p/Picture1.pnghttp://s2.postimg.org/8aqyserzd/Picture1.png |
the wiring diagram shows a white with black tracer wire and a gray with white tracer wire.
I have no other loose wires in the engine compartment, I don't think they would have yanked it either...
The wires in the picture are white/black and green/white |
ooops, yeah its a green wire. it says g/b, i thought it was grey, but green it is.
Doesn't look like a Toyota Reservoir on the Master Cylinder either.
I know that some 95's do not have the sensor wire. I was just working on my brother's 4Runner this past weekend (bone stock, only 90k miles in great shape) and I noticed there is no sensor or float in the brake fluid reservoir and no wires.
The previous owner may have purchased a new reservoir that had wires when none were necessary. Or, they might have yanked the wires if there was a malfunction, say the brake light wouldn't turn off. My question is... if it doesn't light up, who cares? Unless you're losing brake fluid, which then implies a bigger question of, what is leaking? |
