5 spd tranny
Old 05-22-2015, 07:01 PM
greaseball's Avatar
5 spd tranny
i have a 5 spd tranny out of a 1980 pickup with a 20r motor. the only problem with it is 5th and reverse gears are a little iffy .they were towing a nissan pathfinder across washington state from seattle to spokane and as they were going uphill in vantage they downshifted and missed a gear. it looks like just two gears are affected. are these easy to fix and will it bolt up behind a 22r in a 88 pickup?
Old 05-23-2015, 12:32 AM
Fossilized
Staff
dropzone's Avatar
it will bolt up behind any 22R but the problem with an L Series transmission out of a 1st Gen (79-83) truck is that it is 4" shorter than the W Series transmission in an 88. You would need to move the crossmember forward, lengthen the rear driveshaft and shorten the front driveshaft to make it work.
You would be better off finding a G or W series 5 speed to use as a replacement since they would be direct replacement
Old 05-23-2015, 12:38 AM
wyoming9's Avatar
Red face
Besides what Dropzone said !!!
One never knows just what one may find once things like that come apart.Some parts might be very hard to find as well
I would say get a Marlin Crawler rebuilt and be done
Old 05-24-2015, 11:49 AM
greaseball's Avatar
i was thinking more along the line of pull and save to save a little money.
Old 05-24-2015, 12:13 PM
wyoming9's Avatar
Red face
Well one needs to work within the budget.
I got a used W-56 I got a month out of it till I had to drive holding it in gear.
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
Davebarbier
11-03-2015 03:28 PM
Dale Johnston
11
10-31-2015 10:22 PM
Quick Reply: 5 spd tranny
