1987 22re 4 runner help!!
Old 11-11-2014, 03:58 PM
Yota4Runner86's Avatar
A friend of mine has a 1987 toyota 4runner SR5 automatic. He did the timing chain on It yesterday and didn't pull the head.
It was running fine and perfect. Had just over 150'000 on it, he drove it in the shop shut it off and tore her down. Got it all back together and it's not noiding the injectors. It will noid them only once then nothing.
We can hear the flap in the vafm opening and it had fuel pressure. Then we found it is only noiding the injectors the one time. Then nothing, we have checked all grounds and even swapped distributers with a known good one.
Only connector that has been loose was the distributer and the one that goes over to the ignitor.
Old 11-12-2014, 07:32 AM
Bump we still can't figure it out
Old 11-12-2014, 07:37 AM
RJR
RJR's Avatar
Check the distributor and ignitor are all plugged back in correctly. If the ECU doesn't get an IGF pulse back from the ignition system after a few revolutions, it shuts down the injectors.
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 1987 22re 4 runner help!!
