YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-19-2008, 03:09 PM   #1 (permalink)
hmmwv15's Avatar
fuel injectors
I think one of mine is leaking. I can see gas leaking very badly from something, and I'm 99.999% sure that it is a fuel injector. This is my first fuel injected engine, so I really have no knowledge on how exactly to take it apart or what I should expect, how long it will take or what to replace. I could just jump in and start dismantleing things but I'd rather have some ideas on how to do it and make sure that everything goes back in place the way it should. I would appreciate any advice.
__________________
Sean
What I be drivin':
Weekend/fun rig: 85 4runner in the building process, so far welded rear and a wee bit-o-lift. (thing 1)
Daily Driver: 87 extra cab long bed *deluxe* 2wd p/u
(thing 2)
Is this going to be an Obamanation?
hmmwv15 is offline
Sponsored Links
To remove this ad, register today!
Old 05-19-2008, 04:12 PM   #2 (permalink)
4Crawler's Avatar
Best option is to pull all of them and send them off to a shop to clean/rebuild/balance:
- http://www.4crawler.com/4x4/CheapTri...html#Injectors
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 05-21-2008, 06:02 PM   #3 (permalink)
hmmwv15's Avatar
While removing, I snapped off one of those black plastic things that cover the tip. Do I really need it because I have ordered all the gaskets and o rings I need for all four injectors. If I do need it, does anyone have a spare fuel injector I can buy for cheap?
__________________
Sean
What I be drivin':
(thing 2)
hmmwv15 is offline
Old 05-21-2008, 06:40 PM   #4 (permalink)
ahickman's Avatar
I had the same situation (broken pintle cap) and was told it effectively made no operational difference. However, I went ahead and sent all four injectors to Witchhunter.com to have them tested and cleaned (150K miles). Well worth the money and especially quick turn around. Sent them on a Friday and had them back in the rail on Thursday. Included in the work are all new seals and pintle caps.
ahickman is offline
Old 05-21-2008, 06:52 PM   #5 (permalink)
hmmwv15's Avatar
so that was about a week right?
__________________
Sean
What I be drivin':
(thing 2)
hmmwv15 is offline
Old 05-21-2008, 06:54 PM   #6 (permalink)
hmmwv15's Avatar
Reason being is that I am registered for the SE4RJ (south east 4runner jamboree) and it's in less than two weeks. I am struggling to get this thing going by then.
__________________
Sean
What I be drivin':
(thing 2)
hmmwv15 is offline
Old 05-21-2008, 07:01 PM   #7 (permalink)
ahickman's Avatar
Yeah, I was worried about the turn around time too. I chose Witchhunter based on the number of positive threads in this forum in addition to calling ahead and talking with them. I sent them USPS and had them returned USPS which seemed risky, but worked out well (less than a week in total). You might pay the extra for expedited shipping both ways if you are worried? Call and talk to them if you are unsure. Very friendly and informative. I am getting ready to ship off the six from my Runner.
aaron
__________________
River's Father
94 4Runner SR5 Stock 3.0L 3VZE | red | 31 BFG's | rebuild in progress
94 Pickup -- Stock 2.4L 22RE | red | 31's BFG's | rebuild 2007
Mercedez E320 -- Stock | champaign | GY's | mint
ahickman is offline
Old 05-22-2008, 12:20 PM   #8 (permalink)
hmmwv15's Avatar
I may have to do that, just have to save up first.
__________________
Sean
What I be drivin':
(thing 2)
hmmwv15 is offline
Old 05-22-2008, 01:35 PM   #9 (permalink)
rdlsz24's Avatar
Send a message via AIM to rdlsz24
A rebuild kit should include the caps. This one is a good deal if you are only going to refresh them and not have them cleaned by Witchhunter, etc:
http://cm.ebay.com/cm/ck/1065-29392-...m=300226126718
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd)
Rancho lift w/ 33x12.5x15 tires & 5.29s
rdlsz24 is offline
Old 05-22-2008, 02:15 PM   #10 (permalink)
hmmwv15's Avatar
wow. paid $14 at O'rielly's for their rebuild kit which only included all the rubber o rings. no new pintle caps or filters. I guess I could return them though...
__________________
Sean
What I be drivin':
(thing 2)
hmmwv15 is offline
Old 05-23-2008, 06:27 AM   #11 (permalink)
chuggins143's Avatar
...just as a data point, a whole new injector from VatoZone is only ~$50... now that's not a Bosch, they are like $300 each. Shouldn't make any difference if it'll fit in the hole.
Good luck!
C
__________________
85 Toy PU @ +4", on 37's, flat bed, stretched to 120"+ WB, Marlin Crawler, 5:29's, open (Aussie Locker on the way!)/spool, crossover steering, doorless... most of the time!
yet another 85 - work in progress... rattling, but not rolling... yet!
87 Turbo truck... not running
chuggins143 is offline
Old 05-23-2008, 09:10 AM   #12 (permalink)
rdlsz24's Avatar
Quote:
Yeah you get them quick too. I have ordered two kits from him. One for the '94 injectors I sold and another for the '88 injectors I have in my truck now. Just make sure you get the kit that is right for your truck. He has another auction for before '88 since that is when they changed.
Rob
__________________
rdlsz24 is offline
Old 05-23-2008, 09:39 AM   #13 (permalink)
hmmwv15's Avatar
Yeah I don't necessarily have any money to spend on fixing it in such a short amount of time anyway.
__________________
Sean
What I be drivin':
(thing 2)
hmmwv15 is offline
Old 05-24-2008, 02:44 PM   #14 (permalink)
hmmwv15's Avatar
Well, I swapped injectors with someone local and got them in. Tried to crank it up and it acted like it wanted to start at first, then all it did was turn over. I'm about to set fire to the whole thing and watch it burn to the ground so I won't have to worry about it anymore... Anyone have any suggestions? I think my fuel pump went out or something.
__________________
Sean
What I be drivin':
(thing 2)
hmmwv15 is offline
Old 05-24-2008, 02:51 PM   #15 (permalink)
4Crawler's Avatar
Try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 05-29-2008, 03:30 PM   #16 (permalink)
hmmwv15's Avatar
Fuel pump I had to rig up a manual switch to get it to work, getting fuel pressure and spark, still not cranking....Who wants to help me push it off a cliff? I think I'll just start saving for an 85 engine and wiring harness so I know everything is stock...
__________________
Sean
What I be drivin':
(thing 2)
hmmwv15 is offline
Old 06-02-2008, 11:59 PM   #17 (permalink)
I thought my #1 injector was leaking so I dripped some light oil down it while turning it back and forth. Seemed to work. This must be irrelavant since the o-ring is at the top not the bottom.
pcmentor is offline
Old 06-04-2008, 04:14 PM   #18 (permalink)
hmmwv15's Avatar
Can ANYONE give me any tips?! I'm getting fed up with this thing and want it fixed so I can drive it! PLEASE!
__________________
Sean
What I be drivin':
(thing 2)
hmmwv15 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Fuel injectors DWEINBERG01 Newbie Tech Section 1 12-25-2007 11:45 PM
FUEL INJECTORS (Help!) keithguts 86-95 Trucks & 4Runners 3 11-08-2006 12:29 PM
Fuel Injectors 92 4R SirJames 86-95 Trucks & 4Runners 3 08-22-2006 05:58 PM
Fuel injectors Carlos 95.5-2004 Tacomas & 96-2002 4Runners 1 12-11-2004 03:31 PM
Aftermarket Fuel Injectors/Fuel Rails Bumpin' Yota 95.5-2004 Tacomas & 96-2002 4Runners 1 03-17-2003 08:05 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
