fuel injectors
Old May 19, 2008 | 02:09 PM
hmmwv15's Avatar
fuel injectors
I think one of mine is leaking. I can see gas leaking very badly from something, and I'm 99.999% sure that it is a fuel injector. This is my first fuel injected engine, so I really have no knowledge on how exactly to take it apart or what I should expect, how long it will take or what to replace. I could just jump in and start dismantleing things but I'd rather have some ideas on how to do it and make sure that everything goes back in place the way it should. I would appreciate any advice.
Old May 19, 2008 | 03:12 PM
4Crawler's Avatar
Best option is to pull all of them and send them off to a shop to clean/rebuild/balance:
- http://www.4crawler.com/4x4/CheapTri...html#Injectors
Old May 21, 2008 | 05:02 PM
hmmwv15's Avatar
While removing, I snapped off one of those black plastic things that cover the tip. Do I really need it because I have ordered all the gaskets and o rings I need for all four injectors. If I do need it, does anyone have a spare fuel injector I can buy for cheap?
Old May 21, 2008 | 05:40 PM
ahickman's Avatar
I had the same situation (broken pintle cap) and was told it effectively made no operational difference. However, I went ahead and sent all four injectors to Witchhunter.com to have them tested and cleaned (150K miles). Well worth the money and especially quick turn around. Sent them on a Friday and had them back in the rail on Thursday. Included in the work are all new seals and pintle caps.
Old May 21, 2008 | 05:52 PM
hmmwv15's Avatar
so that was about a week right?
Old May 21, 2008 | 05:54 PM
hmmwv15's Avatar
Reason being is that I am registered for the SE4RJ (south east 4runner jamboree) and it's in less than two weeks. I am struggling to get this thing going by then.
Old May 21, 2008 | 06:01 PM
ahickman's Avatar
Yeah, I was worried about the turn around time too. I chose Witchhunter based on the number of positive threads in this forum in addition to calling ahead and talking with them. I sent them USPS and had them returned USPS which seemed risky, but worked out well (less than a week in total). You might pay the extra for expedited shipping both ways if you are worried? Call and talk to them if you are unsure. Very friendly and informative. I am getting ready to ship off the six from my Runner.
aaron
Old May 22, 2008 | 11:20 AM
hmmwv15's Avatar
I may have to do that, just have to save up first.
Old May 22, 2008 | 12:35 PM
rdlsz24's Avatar
A rebuild kit should include the caps. This one is a good deal if you are only going to refresh them and not have them cleaned by Witchhunter, etc:
http://cm.ebay.com/cm/ck/1065-29392-...m=300226126718
Rob
Old May 22, 2008 | 01:15 PM
hmmwv15's Avatar
wow. paid $14 at O'rielly's for their rebuild kit which only included all the rubber o rings. no new pintle caps or filters. I guess I could return them though...
Old May 23, 2008 | 05:27 AM
chuggins143's Avatar
...just as a data point, a whole new injector from VatoZone is only ~$50... now that's not a Bosch, they are like $300 each. Shouldn't make any difference if it'll fit in the hole.
Good luck!
C
Old May 23, 2008 | 08:10 AM
rdlsz24's Avatar
Yeah you get them quick too. I have ordered two kits from him. One for the '94 injectors I sold and another for the '88 injectors I have in my truck now. Just make sure you get the kit that is right for your truck. He has another auction for before '88 since that is when they changed.
Rob
Old May 23, 2008 | 08:39 AM
hmmwv15's Avatar
Yeah I don't necessarily have any money to spend on fixing it in such a short amount of time anyway.
Old May 24, 2008 | 01:44 PM
hmmwv15's Avatar
Well, I swapped injectors with someone local and got them in. Tried to crank it up and it acted like it wanted to start at first, then all it did was turn over. I'm about to set fire to the whole thing and watch it burn to the ground so I won't have to worry about it anymore... Anyone have any suggestions? I think my fuel pump went out or something.
Old May 24, 2008 | 01:51 PM
4Crawler's Avatar
Try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old May 29, 2008 | 02:30 PM
hmmwv15's Avatar
Fuel pump I had to rig up a manual switch to get it to work, getting fuel pressure and spark, still not cranking....Who wants to help me push it off a cliff? I think I'll just start saving for an 85 engine and wiring harness so I know everything is stock...
Old Jun 2, 2008 | 10:59 PM
pcmentor's Avatar
I thought my #1 injector was leaking so I dripped some light oil down it while turning it back and forth. Seemed to work. This must be irrelavant since the o-ring is at the top not the bottom.
Old Jun 4, 2008 | 03:14 PM
hmmwv15's Avatar
Can ANYONE give me any tips?! I'm getting fed up with this thing and want it fixed so I can drive it! PLEASE!
Blamalam
Mar 12, 2022 07:34 AM
RatOmeter
Oct 22, 2015 03:17 PM
Tacoma1313
Aug 17, 2015 05:44 PM
pyramid
Jul 30, 2015 10:05 AM
HookahRoo
Jul 20, 2015 07:06 PM
