Broke something on my motor during rebuild
When I was putting my motor back together I accidently broke this:
I think it was some kind of vacuum inlet/outlet.
Can someone tell me what this is and where I can get a new one?
Thanks,
Leon
Thanks,
Leon
Last edited by waskillywabbit; 02-12-2010 at 08:17 AM. Reason: Use more descriptive titles you will get more help
Looks like the Bi-metal Vacuum Switching Valve (BVSV) for the EGR system. It switches vacuum on to the EGR modulator once the engine warms up. Junkyard or Toyota parts counter to get a replacement:
- http://www.4crawler.com/4x4/index.shtml#VendorLinks
THANK YOU SO MUCH!!!
I really appreciate it. I will search and see if I can find it.
Anyway you know a good way to find the part number for it? or is their any toyota employees on here that can get the part number for a Bi-metal Vacuum Switching Valve for a 1985 Toyota 4x4, 22re, non-turbo?
Thanks
Thanks
If I remember right I think the number was either molded into the plastic peice that broke off or its etched into the brass fitting still there. I think those run about $80 at the dealer. If you need the part number I will try to get it tonight.
will not fixing this right now make my truck not run. I am in the process of getting it running after a new timing chain and head and was wondering if this could be my problem?
MMA_Alex
25
04-18-2017 05:07 AM
