22ret blow off valve
Old 08-21-2010, 01:13 PM
DeathSycthe02's Avatar
Does a factory 22ret truck have a blow off valve installed?
Old 08-21-2010, 05:28 PM
slacker's Avatar
yep ...
Old 08-21-2010, 05:55 PM
jsdesignturboyota's Avatar
Actually they don't, and if you decide to put one on make sure its the plum back kind. If you use a vented one with the stock efi your engine will run rich for a while after your shift.
Old 08-21-2010, 07:43 PM
slacker's Avatar
ahh yeah .. sorry , my bad ..
I for some reason was thinkin waste gate ..
no stock BOV ..
Old 08-27-2010, 07:24 AM
greatskiiiier's Avatar
no BOV, why do you ask?
Old 08-27-2010, 07:28 AM
BoostedRNR's Avatar
Yep no BOV. I have an aftermarket one on and need to re-plumb it back into the intake. If you have an automatic then it wouldn't be a big deal, but since I swapped to a 5 speed, every time I shift, all the air that gets blown off is unmetered air and it falls on its face for a split second
Old 08-14-2018, 06:55 AM
87-4runner's Avatar
I know it's an old thread...
but, the 22rte factory CT20 has an internal wastegate, no need for a BOV...
Old 08-14-2018, 07:14 AM
Co_94_PU's Avatar
This is not correct.
These two devices serve separate functions.
Bov prevents excess pressure on the compressor, "surging" is what it's referenced as Google is your friend.
foampile
12-18-2022 01:29 PM
theking11863
03-19-2016 09:36 PM
fountain
09-19-2015 08:16 PM
o2raybid
09-04-2015 12:45 PM
izzmee
08-17-2015 10:20 AM
Quick Reply: 22ret blow off valve
