Does a factory 22ret truck have a blow off valve installed?
Quote:
yep ... Originally Posted by DeathSycthe02
Actually they don't, and if you decide to put one on make sure its the plum back kind. If you use a vented one with the stock efi your engine will run rich for a while after your shift.
ahh yeah .. sorry , my bad ..
I for some reason was thinkin waste gate ..
no stock BOV ..
no stock BOV ..
Yep no BOV. I have an aftermarket one on and need to re-plumb it back into the intake. If you have an automatic then it wouldn't be a big deal, but since I swapped to a 5 speed, every time I shift, all the air that gets blown off is unmetered air and it falls on its face for a split second
I know it's an old thread...
but, the 22rte factory CT20 has an internal wastegate, no need for a BOV...
This is not correct.Originally Posted by 87-4runner
I know it's an old thread...but, the 22rte factory CT20 has an internal wastegate, no need for a BOV...
These two devices serve separate functions.
Bov prevents excess pressure on the compressor, "surging" is what it's referenced as Google is your friend.
