85 - rear windshield washer
Old Nov 9, 2006 | 04:42 AM
Doc279's Avatar
My 85 has the bag in the driver's side rear compartment. I filled it with
fluid but can't figure out how to turn it on. It doesn't work with the
fwd windshield washer.
I don't have an owners manual and it's not in the Haynes manual.
Old Nov 9, 2006 | 08:31 AM
85TurboRunner's Avatar
it works by pushing the rear wiper switch forward and holding it down.
Old Nov 9, 2006 | 09:08 AM
Doc279's Avatar
Thanks - I'll try it in a little while. Waiting on lunch time here.
Old Nov 9, 2006 | 04:20 PM
Doc279's Avatar
Well it still wouldn't work - so I inspected the bag again and found that the pump wire was disconnected. Works like a charm now !
Now I am looking for the fuse that controls the rear deck light. Any idea where it might be ? I checked the driver side foot fuse box and it's not there.
The FSM does not describe fuse block locations - I also checked the box that is under the hood.
Old Nov 9, 2006 | 07:17 PM
if your talking about the light in the rear cargo area on the drivers side, your headlights have to be on for it to work. at least thats how mine works.
Old Nov 10, 2006 | 04:45 AM
Doc279's Avatar
That's the light, when I first got the runner it would work if the deck lamp switch at the dash was on - without the headlights being on. It quit working
and I've checked for power and ground at the light. I have a good ground but no power. I've also checked every fuse that I can find. I am going to run an accessory power block to the rear area - so I'll just wire it hot.
I bought one of those 12 volt heater/fan units at Walmart - I'm going to mount it on the wiper cover. My runner doesn't have the rear window defroster grid. I also got a couple of the clear flush mount lights that have their own switch - gonna light up the rear !
What's the switch below the cigerette Lighter for ?
Anybody got a scanned owners manual to share ?
Old Nov 10, 2006 | 07:22 AM
AxleIke's Avatar
headlights or parking lights have to be on for it to work. So does the dash switch.
They really don't want you to run down your battery
Old Nov 16, 2006 | 07:58 AM
Greg_Canada's Avatar
haha, i'd be suprised if i left that light on for a day and my battery wouldnt start.
I can run my system for 4 hours and it starts just fine afterwards.
Old Nov 16, 2006 | 10:20 AM
4Crawler's Avatar
I re-powered the deck light switch up front to run from a constant power (instead of switched power) source. Also swapped the incandescent bulb out for a white LED bulb. Works fine and the LED throws out a lot of light and the current draw is very low.
Sep 4, 2015 09:27 AM
chickenhala
Jul 21, 2015 05:41 PM
msane99
Jul 17, 2015 10:13 AM
icentropy
Jul 14, 2015 10:23 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
