85 - rear windshield washer
My 85 has the bag in the driver's side rear compartment. I filled it with
fluid but can't figure out how to turn it on. It doesn't work with the
fwd windshield washer.
I don't have an owners manual and it's not in the Haynes manual.
Well it still wouldn't work - so I inspected the bag again and found that the pump wire was disconnected. Works like a charm now !
Now I am looking for the fuse that controls the rear deck light. Any idea where it might be ? I checked the driver side foot fuse box and it's not there.
The FSM does not describe fuse block locations - I also checked the box that is under the hood.
and I've checked for power and ground at the light. I have a good ground but no power. I've also checked every fuse that I can find. I am going to run an accessory power block to the rear area - so I'll just wire it hot.
I bought one of those 12 volt heater/fan units at Walmart - I'm going to mount it on the wiper cover. My runner doesn't have the rear window defroster grid. I also got a couple of the clear flush mount lights that have their own switch - gonna light up the rear !
What's the switch below the cigerette Lighter for ?
Anybody got a scanned owners manual to share ?
I can run my system for 4 hours and it starts just fine afterwards.
I re-powered the deck light switch up front to run from a constant power (instead of switched power) source. Also swapped the incandescent bulb out for a white LED bulb. Works fine and the LED throws out a lot of light and the current draw is very low.
Sep 4, 2015 09:27 AM
icentropy
Jul 14, 2015 10:23 AM
