Product Reviews Post your reviews on automotive and expedition-camping gear here
Lc header
Old Oct 20, 2006 | 03:54 PM
bodo's Avatar
Lc header
Great header very thick flange, nicely coated, and clears great. This is on an 89' pickup, 22re, 5 speed, and allpros sac. This thing is well built and you can tell by the welds, finish, and weight.
Old Oct 20, 2006 | 04:17 PM
crackerjack's Avatar
second that....And I'm not just saying that because they gave me a hat
Old Jan 21, 2009 | 07:04 AM
Flek23's Avatar
Not as Happy as the rest
First let me say that my 91 was stock and no other mods have been added as of today. I bought an LC Engineering header in 2002. For a short time i did experience an increase in HP. Then the problems began, I've burned up O2 sensor after O2 sensor, Throttle sensors and have never been able to get good long lasting gasket seal on the exhaust. I have now unplugged the O2 sensors and it's running better. The ceramic coat held up for about two years. My perspective at this point is that when I finish with my 83 build I will go back to stock exhaust on my 91. Perhaps LC's exhaust is a good set up if you are doing drastic changes and understand how to change the trucks brain settings but if you are an average Joe looking to bolt up and go I think you may have the issues I ran into.
Old Apr 23, 2009 | 06:18 AM
4Crawler's Avatar
I hanve had my LC header for about 10 years now. Have replaced one O2 sensor that wore out (was used before the header was installed) and still using the original gasket. I did go to stainless steel hardware to hold the sensor in place. Throttle position sensor should not be affected by the header, I am still on what I think is the original TPS on my '85, at least it is the one that was on there when I bought it in '96. Ceramic coat is still intact, only the block off plates that I painted with hi-temp paint have a touch of corrosion, I have since repainted them:
http://www.4crawler.com/4x4/CheapTri....shtml#Exhaust
The only issues I have had have been the flange gasket with I replaced with a home made copper gasket that has held up for about 10 years now. And also I found the weld beads inside the EGR ports were impeding exhaust gas flow and hurting my smog (NOx) readings. So I had to use a Dremel to grind those beads down to flow better.
Old May 2, 2012 | 05:39 PM
cheapneasycrndog's Avatar
they gave you a hat! I too love my headers as they fit, sound, and seem to flow great!
Old Mar 17, 2013 | 08:31 AM
yota1016's Avatar
If I put headers on my 3.slow will I get much of a power increase???
Old Dec 14, 2015 | 10:04 PM
8yota8's Avatar
Just put the lce header on my 88 yota truck 22re last week and 21/2 pipe 40 series flowmaster kept the cat on sounds great I thought it would be louder but it has a nice low tone. The original exhaust manifold was cracked and also leaked. the rest of the exhaust pipe and muffler were original and they definitely showed it
Old Mar 10, 2019 | 06:28 PM
muddpigg's Avatar
Just installed the LCE header. Had been running a Doug Thorley Tri-y for last 12yrs. One test drive so far but very excited with results. Its like the other mods woke-up.
TheBFA
Feb 15, 2020 06:55 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
voiddweller
Sep 28, 2015 11:21 PM
toyotasaurus
Sep 24, 2015 03:30 PM
DiggnDeep
Sep 3, 2015 02:45 PM
