Fab a filler neck extension or buy one?
I just bought a 4runner with a 3" body lift installed, the rigged the filler neck after the body lift and it leaks gas
Can you buy these extensions somewhere or would it be just as easy to cut some rubber hose of some kind and clamp it in?
Don't use anything but fuel hose (something specified to handle gas) or check for a gas filler extension at places like JCWhitney, Summit, JEGS, etc.
Steel pipe is gonna rust like crazy over time when exposed to gas/air and put all that crap/rust/scale in your gas tank and then your fuel filter. Bad idea.
I used a plastic pipe from a radiator hose repair kit. The guy at autozone told me it would not work cause its plastic and the gas would destroy it. I looked at him and the huge stack of PLASTIC gas cans they had on display and told him I would take my chances. No problems so far.
I generally cut the hose in half and go to the muffler shop and get a piece of pipe cut to fit and then clamp it.
RobotMoose
Feb 22, 2020 07:44 AM
