Fab a filler neck extension or buy one?
Old Sep 30, 2006 | 08:28 AM
nineball's Avatar
I just bought a 4runner with a 3" body lift installed, the rigged the filler neck after the body lift and it leaks gas Can you buy these extensions somewhere or would it be just as easy to cut some rubber hose of some kind and clamp it in?
Old Sep 30, 2006 | 09:19 AM
Yoda's Avatar
I don't know what yours is like, but I have bought fuel filler hose and cut it to the length I needed.
Don't use radiator hose.
Old Oct 6, 2006 | 09:27 AM
yellowspeedracer's Avatar
I just cut the factory hose, added in a piece of steel pipe and put hose clamps on it. Seems to be working for me. I also had to add a spacer where the pipe mounts to the frame.
Old Oct 6, 2006 | 10:10 AM
waskillywabbit's Avatar
Don't use anything but fuel hose (something specified to handle gas) or check for a gas filler extension at places like JCWhitney, Summit, JEGS, etc.
Steel pipe is gonna rust like crazy over time when exposed to gas/air and put all that crap/rust/scale in your gas tank and then your fuel filter. Bad idea.
Old Oct 6, 2006 | 10:29 AM
Buck01's Avatar
I used a plastic pipe from a radiator hose repair kit. The guy at autozone told me it would not work cause its plastic and the gas would destroy it. I looked at him and the huge stack of PLASTIC gas cans they had on display and told him I would take my chances. No problems so far.
Old Oct 7, 2006 | 04:02 AM
millertime_t1's Avatar
I agree 100%
I generally cut the hose in half and go to the muffler shop and get a piece of pipe cut to fit and then clamp it.
Old Oct 7, 2006 | 07:13 PM
4x4mike's Avatar
Guest
Performance accessories
My PA BL came with a metal filler neck extension. Call them up and see if you can get just that part. Makes sense to do it right.
Old Oct 7, 2006 | 07:36 PM
SoiledGreen98's Avatar
Just go to carquest and get the length you need. It may be a little more pricey but you'll have the peace of mind not having to worry about it any more.
Old Oct 8, 2006 | 08:28 PM
nineball's Avatar
went to home depot and bought a peice of 1" 1/4 pvc for $4 spliced it in and clamped it, shes ready for the road!!
RobotMoose
Feb 22, 2020 07:44 AM
Obmi
Sep 10, 2016 04:40 AM
pickle6415
Oct 19, 2015 08:08 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
matthew138
Sep 3, 2015 08:21 AM
