Will frt & rear 3rds inerchange
Generally lockers and limited slips will swap no problems. Only one that may be an issue is the TrueTrac that is supposed to have different units for front and rear axle use.
Originally Posted by seaflea
Yes it will also fit.
I am assuming you are putting these 3rds in a solid axle truck. Is that correct?
spool the rear & probly go with a aussie locker in the frt if the powertrac will not work.
Ill dig some up .I still have the sammy axles under it till I have all parts together .at the momet im running 462 in the diffs 4.1 t/case yj missing links frt 1/4 eliptic 4 link rear with 33 tsl,s in a 88 tintop but iv got a set of 36 Irocs on beadlocks to go on & im doing good to run 33s with the sammy axles so its time to step up to toy,s& 100 inch wheelbase
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
THANKS
THANKS So will a locker that came from a rear go in the frt? I want to put a spool in the rear & a locker in the frt & I have a powertrac out of a rear I was hoping to usein the frt.
