motor bad on the back window
Old Nov 15, 2005 | 01:22 PM
854runner's Avatar
Question motor bad on the back window
On my 4runner i am trying to get all the little things to work right. Back window does not work. PO said it was off the track, i looked fine to me. No noise are anything from the motor on the window. No idea what is wrong with it. not sure how to test for it either. As always thx guys mike
Old Nov 15, 2005 | 01:30 PM
bob200587's Avatar
all i know is that if the motor is bad. be prepared to spend $250 on a new one. Make sure you get one with a warranty.
Old Nov 15, 2005 | 02:23 PM
854runner's Avatar
WOW, what makes it 250?? alot more then i thought it would be.
mike
Old Nov 15, 2005 | 02:26 PM
Gangus2006's Avatar
What year is your truck? Does the window move at all?
Old Nov 15, 2005 | 02:40 PM
runethechamp's Avatar
One advice: check out ebay. I've seen a couple of those motors around there.
Old Nov 15, 2005 | 02:49 PM
854runner's Avatar
its a 85. window does not do a thing. mike
Old Nov 15, 2005 | 02:50 PM
garrett1478's Avatar
what about the switch or relay
Old Nov 15, 2005 | 02:54 PM
gohawks's Avatar
Here's a link to check out, maybe Roger will chime in, he's the master of all things 4Runner!
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old Nov 15, 2005 | 03:25 PM
Intrepid's Avatar
Skip the motor if it is bad, buy a used tailgate and paint it.
Old Nov 15, 2005 | 03:53 PM
DudeBud's Avatar
one from an older camry should work? also i would check the wiring and switches its all on Rodger's site
Old Nov 15, 2005 | 05:46 PM
854runner's Avatar
thx guys link does not work for me.
Old Nov 15, 2005 | 06:17 PM
bob200587's Avatar
mike
it was 250 for a new one....and I don't think it was an original part, somethin else, but It came with a warranty, don't remember how long. When it comes down to it. Its worth it rather than searching ebay or junkyards, since you'll spend way more time than its worth than taking it to a shop and letting them fix it.
Old Nov 15, 2005 | 08:01 PM
rudestar's Avatar
Pull the gate trim and metal cover panel. Unplug motor and jump it with 12 volts. Change polarity to reverse direction. To pull regulator assembly disconect wires, latch & lock rods and lock cables. Remove the four 10mm bolts, slide towards passengers side and tilt to lower into gate. Slide from side to side to disconnect from glass channels, unplug wires from glass and remove. Remove regulator assembly by tilting top up as you slide towards drivers side. Most common trouble with regulator is worn out / missing nylon wheels in end of arms. Check teeth for wear, when removing motor be ready for spring loaded arms to fly up when motor gear disengages. Used motor is $20.00 to $40.00, complete regulator assy $30.00 to $75.00 depending on condition. Can be replaced in 15 minuets if you have done the job before.
Old Nov 15, 2005 | 08:05 PM
4Crawler's Avatar
Works fine for me, try it again...
Old Nov 16, 2005 | 04:20 AM
854runner's Avatar
thanks link still does not work tho. There must be a bug in my pc. I think. dont know what else it could be
mike
Old Nov 16, 2005 | 07:18 AM
4Crawler's Avatar
What error are you getting?
Here is an alternate address to try.
Old Nov 16, 2005 | 07:23 AM
854runner's Avatar
got it when i coped it. I click on it and it does not do a thing, at all. Where can i find a Fusible link? thx
mike
Old Nov 16, 2005 | 07:33 AM
4Crawler's Avatar
What "does not do a thing"? If you are referring to the entire truck, then yes, a fusible link would be susepct, since almost *everything* electrical on the truck (outside the starter) runs through the fusible link. If you are only referring rear window, then continue on down the troubleshooting steps.
Old Nov 16, 2005 | 07:55 AM
sutlTL's Avatar
I recall someone on here changed their motor with one from a Camry. I'm not sure if it was left or right side but I think one side was mentioned. Try a search.
Old Nov 16, 2005 | 08:44 AM
854runner's Avatar
I will try a search. I thought if the motor was good it would at lease make some kinda sound. Doesnt even do that. I will give it a try thx guys
voiddweller
19
May 2, 2016 09:10 PM
scottt80
Jul 1, 2015 12:13 PM
infinityisfive
Jun 16, 2015 06:51 PM
Corey
Jun 19, 2002 11:06 AM
