Steering Popping?
Steering Popping?
Ok, so I just got my front differential put into my 1989 V6 4x4 pickup, and the 4wd is working perfectly... except that I "pop" when I turn while going slow... its just a little popping sound and I dont know why its happening, so do you guys have any ideas?
What sort of terrain are you testing the 4WD operation on? If on pavement or other high traction surface, you may simply be experiencing part time 4WD driveline binding. Generally not a good idea to use 4WD on pavement as the binding that occurs puts a lot of stress on things.
Otherwise, it may be a CV joint that is binding up and popping on you.
nah, i think he means it's coming from the diff. like when it's binding.
if he's at full lock and is turning/accelerating and/or hitting bumps at full lock, that's when the stops come into play.
edit:this was to matt/celica =)
I actually have this same problem but it is not related to 4wd. Mine does it when I turn slightly or like when I turn to pull into my drive way. Its not the noise you hear from the steering stops. It literally sounds like popping. Stearing stops to me sound more like a squeaking. Anybody know what that might be?
1uzRunner
63
Nov 10, 2018 03:58 PM
