Transfer Case Compatable?
Old Oct 2, 2005 | 08:19 PM
Dave & Cindy's Avatar
Just bought 86 4Runner which has had tranny & transfer case from 92 pickup installed. Problem is the transfer case shift lever does not fit the console. Looking at the top of the transfer case, it appears as though the shifter might be able to be moved to the rear position by changing places with the rear cover and the shifter. Both are 22 RE manual trans. I have not removed anything yet. Does anyone know if this will work, or if there are additional parts needed?
Old Oct 3, 2005 | 07:56 AM
Silver_Truck's Avatar
Not quite sure what you're ralking about with rear position...you might want to take a look at your old t case and see if it was top or foward shift then make sure you're new one is the same.
Old Oct 3, 2005 | 09:24 AM
GRNTACO's Avatar
The transmission shifter will not fit the t-case. I'm not sure of the question.
Old Oct 3, 2005 | 01:34 PM
on top of the transfer case is where the shifter is located. it appears there is a position to the rear of where the shifter is on the transfer case where it might be able to be placed. does the 4 runner and the pickup use the same transfer case? I get a pic.
Old Oct 3, 2005 | 01:36 PM
GRNTACO's Avatar
It would depend on the year of t-case in question. I would like to see a pic if you have one.
Old Oct 3, 2005 | 01:47 PM
4Crawler's Avatar
Likely your old case was a top-shift, the new case a forward shift. Either convert the new case to top shift (see link below):
- http://www.4x4wire.com/toyota/tech/topshifter/
Of swap the old case (if you still have access to it) onto the new tranny, or cut a larger hole in the floor for the new t-case shifter.
Old Oct 3, 2005 | 06:32 PM
kyle_22r's Avatar
yep, the shift rails are different so it isn't as easy as swapping the plates.
Old Oct 3, 2005 | 09:05 PM
4 Crawler, your photos and explanation seem to show exactly what I have. I will try to get ahold of the old case. I have not seen this thing apart yet, just the view from the access hole in the floorboard. I've been out tracking down other parts to make the rest of the runner function properly. Thanks for all the advice guys.
Old Oct 4, 2005 | 07:24 PM
kyle_22r's Avatar
a bolt-in case will come from an '85-88 pickup or 4runner with a 5 speed and EFI. '79-83 will also work, put with '79-80 you'll have to grind the splines a little and swap the flanges with the ones from your truck, and '81-83 you'll have to swap the flanges.
zytra
Jan 24, 2019 03:16 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Phantez
Sep 30, 2015 08:24 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
