22 re rod knocking
22 re rod knocking
I have gatherd a pretty general redneck consensus that I can replace my rod bearings by dropping the oil pan and if the crank is'nt in to bad of shape it should be no prob. The knock is noticeable on startup and quickly fades to being barely noticeable with the hood open. Has anyone tried this fix or is it a foolish and temporary fix?
This sounds more like an exhaust leak than a rod knock. In my experience, rod knocking gets worse as the engine warms, whereas exhaust leaks take about 1 minute to quiet down. The 22R is also prone to collector leaks.
Yeah, just had the exhaust buttoned up, soon as the oil gets flowin' it stops, or hushes should I say.
It's only loud for as long as it takes to get the oil circulating. I basically just wanted to know if anyone out there has changed the rod bearings through the oil pan successfully. Another thing I was interested in was the toyota repair manual mentions that the rods will be stamped either a, b, c, or d and that the corresponding bearings should be used. Parts guy at Roy Rodgers says that it doesn't matter and that he has sold a hundred standard size sets.
unless you go to toyota and pick out your bearings(heck, they might even sell total sets of the same), a rod bearing is a rod bearing when it comes to a 22R. mine were stamped with numbers and letters but i've had no ill effects of using a generic set.
same goes with the crank, but there's 3 unique sets of main bearings for the early 22R and late 22R(2 are for early, 1 for late). the order for those are stamped on the bottom of the block inside where the oilpan gasket goes.\
all the toyota genuine bearings i pulled out of my engine before rebuilding looked the same to me.
ah ha, this is true, the oil filter is not toyota, but I am afraid still that I have a bad bearing. I just bought this truck on ebay and other than the body it is in pretty rough shape. I have no maintenance records and the carfax shows the truck has been through quite a few owners. It looks as if the top end has had some work done to it recently(nice and shiny new parts), but the whole block is covered in oil as if possibly a bad valve cover gasket. It does not seem to be leaking any oil at all at the moment. I am planning on dropping the oil pan to check the condition of the rods. I have owned a 22r previously and I am very familliar with the infamous tick and generic oil filter problems. I have a toyota filter and will change the oil again just to see.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
