54 mm spindle nut socket
Old Jan 31, 2003 | 03:10 PM
channer's Avatar
Okay, this time I did a thorough search of the forums, and I can't seem to find out where I can buy or rent a 54 mm socket.
I have called AutoZone, Advance, Napa, PepBoys... none seem to have it. Any suggestions?
Old Jan 31, 2003 | 03:24 PM
Corey's Avatar
Co-Founder/Administrator
Somebody putting on some manual hubs soon?
I hear a Sears socket sized at 2 1/8 is the same size as 54 mm and should work.
I think Sears does carry one also.
Old Jan 31, 2003 | 04:26 PM
oly884's Avatar
Guest
I recently did my brakes, and a 2 1/8 works. NAPA carries them, but I had to get mine ordered.
Old Jan 31, 2003 | 04:39 PM
channer's Avatar
Thanks for the info. Sears shows it online, hopefully they have it at the store, because my Mom won't loan me her IS 300 for long!
Sears 2-1/8" Socket
Old Jan 31, 2003 | 04:54 PM
Shane's Avatar
The Sears one is nice, makes for a handy compact hammer too 'cause it's beefy. You'll likely need a 3/4-1/2 drive adapter too...
Old Jan 31, 2003 | 10:10 PM
RWD
http://www.sleeoffroad.com/products/...train_main.htm
Old Feb 1, 2003 | 08:40 AM
Arnold's Avatar
I got mine at my local Toyota dealer.
Old Feb 1, 2003 | 01:05 PM
Cebby's Avatar
Got mine today at Sears
Got a 2 1/8" and adapter today (thanks Shane, I'd have forgotten) Socket was around $20, adapter was $7. I'm going to repain my hub dials for the 3rd time. First try was with body shop paint through a sprayer (turned out like ˟˟˟˟˟ - paint must have had hardner in it or something - like trying to spray molasses), 2nd was with the yellow my tow hook is painted with (the wife talked me into it - poor coverage, weird buildup at the letters). 3rd time is a charm - got some Plasticoat touchup spray to match the body.
Old Feb 4, 2003 | 12:57 PM
Firescooby's Avatar
Are these needed in the new Tacomas? I have a 2002 and had a 1994 and have a 54mm socket from NWOR that I had to buy when I redid my hubs.
IF it is not needed in my Tacom I was gonna sell it.
Old Feb 4, 2003 | 08:33 PM
Adam F's Avatar
No, Tacoma's and 3rd gen 4Runners use a 36mm socket
Old Feb 6, 2003 | 07:47 PM
oldsub86's Avatar
I got a 54 mm socket last fall at my local autoparts store. They had lots of different ones for various 4X4 hubs including the one for the 2nd generation Runners. It was expensive and obviously has limited uses but was worth it to me. It is thin walled so it fits without rubbing. Someone suggested that the 2 1/8 sockets can sometimes be a bit tight. I don't recall the brand on mine and it is out in the cold garage so I am not going to look right now but if you have trouble finding one, post again and I will look and tell you what the brand name is.
Old Feb 21, 2003 | 05:29 AM
Firefyter-Emt's Avatar
believe it or not.. this is one socket that is not expensive thru Snap-On.. and it is the correct socket.. (I think I paid under $20)
Old Feb 21, 2003 | 04:30 PM
Yoda's Avatar
My local NAPA has the OTC 54MM socket for toyota hubs for less than $15. And it is 1/2 inch drive. It has a newer number now (7612??) The one I have is 6612
I think the 95 (or so) Runners use a different socket (more expensive)
Old Feb 24, 2003 | 08:09 PM
4x4CPOSEADOG's Avatar
I got mine from the guy ( I think he is a dealer) who drives Snap On truck for 16.55 plus Va tax and went to Sears to get the 1/2 to 3/4 drive adapter for 6.99 and since I was at Sears I decided to grab a torque wrench that goes from 5-80 ft lbs for $76 dollars, they were on sale. I need these tools to install the manual locking hubs. Below is the picture.
Noel
Attached Thumbnails 54 mm spindle nut socket-54mm-socket-half-inch-three-quarter-adapter.jpg
G-off
Dec 29, 2015 12:44 PM
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
