99 4 runner inner fender removal
Hello
I'm trying to remove the front inner fender to access a broken power antenna on my 99 4 runner. How do you remove the plugs that fasten the plastic inner liner and also anchor the fender flares? Is a special tool required?
Thanks for the help..
Check Bob's write-up for replacing the antenna. It has detailed pics and instructions in removing the inner fender too. Here the link:
Antenna/fender removal
george
george
Thanks
My question is more pertaining to removing the plug itself. Do you simply pry them off? Looks like this is impossible without damaging them. Are these plugs something that needs to be replaced once removed?
Thanks
Thanks
Sorry I stumbled across this thread a little too late but these clips are (relatively)easily removed by first removing the screw (some might not have screws) that is in them then using a pick tool (like an ice pick with the last 1/2" of the tip bent to a right angle) poked into the hole and pry the barbs (2) into the center of the hole. A little difficult to explain in words but I recently replaced the mast on my power antenna without breaking any of the clips. Hopefully this helps someone in the future. Or heck, you could just buy new clips.
Great Post... wanted to add to this excellent thread
Following the instructions here I was able to do this with no issues all by my self. I used Ebay (Bridgewood Motorsports) to pick up the antenna mast. My antenna cable was broke so... When pulling the fender shield (after removing the fender flare completely) I simply broke 2 retaining clips (will purchase replacements later) NOT the bottom left one but the two above it. If you simply break those two that gives you just enough room to pull the fender shield back and get at the 10mm bolt holding the power antenna assembly in. I didn't disconnect any cables simply slid the assembly out and using a Phillips unscrewed the 6 screws holding the motor assembly together. Pulled out the broken antenna cable and closed everything back up. I reinstalled and simply extended the new antenna, put the teeth in facing the front bumper and sat on the passenger seat to power the radio on then off and simply fed the new antenna mast and cable into the unit. Done and now only need to buy two retaining clips.
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
