Headgasket update.
Headgasket update.
well... they have the block apart... it was the head gasket... so they're fixing that.
also they are doing a valve job, they said that some of the valves weren't closing all the way and were starting to burn and warp... so that's gonna add and extra $400 to the job....
so I'm going to be without the 4runner for like 2 weeks total, and out a butt load of money...... :cry:
an extra $400 for a valave job? you are getting shafted?! i had my 22r head machined down, cleaned, pressure tested, all the valve seals replaced and a valve job done for $180
Yeah, $400 for a valve job? I think you're getting forked. Sorry to hear about the HG, too. At least it's not something worse, I guess.
22r/re is alot different that a 3vze head. More valves to replace in the v6, more of a PITA to work on, harder to adjust vavles, etc. A friend of mine just had his heads rebuild and it costed him about $400 for a reputable machine shop.
I know how much it sucks to have your truck crap out on ya, today I think i found out my truck has a burnt valve. How much is the whole thing gonna cost you?
I don't even really know what the cost is at this point... it was $1100 for the headgasket, and that $1100 was assuming I didn't need to replace any other engine components... and now $350-400 for the valve job... so $1450 if i'm hella lucky... but it will most likely be like 1600 or so...
1100 for the head gasket and they werent going to do any of the head work?! dang... i sepnt $400 on my 22r, and i got a whole factory toyota gasket kit, had the machine work done and did the work myself... i know its a v6... but it still seems like he is getting shafted...... thats 4 times the cost and mine was only half the amount of work....
If you haven't already, you might want them to replace the waterpump, timing belt and idler pully thingy.
Since you're throwing around money as it is...
Welcome to the wonderful world of the 3.0.
next time this thing craps out I'm swapping the engine.
Folks, you are all comparing two different machines.
A 22R/22RE is nothing like a 3VZ-E.
Four hundred bones for a valve job does sound reasonable to me.
I have been quoted seven hundred bones for valve adjustment.
It is a time consuming and delicate job.
Finally someone realizes.....
Originally Posted by Cebby
This is the path I could have gone down. All that money......and it's still the 3.slow.
why cant you buy a new head with all new valves etc from engnbldr.com????? wouldnt it cost about the same?
TheBFA
Feb 15, 2020 06:55 AM
_Nicco_
Sep 21, 2015 03:06 PM
defrag4
Jul 31, 2015 10:50 AM
