?? On TC long-travel kit.
I was just wondering this, but:
For the Total Chaos long travel kit, you need modified tundra axles. Now, the tundra axles im guessing are longer, to accomodate the increased travel and increased width of front end from the longer A-Arms.
I wanted to know... What modifications need to be done to them, to fit on a 4runner/Taco??
Is the tri-pod bearing different? W
Whats the difference between the axles besides the length?
The Tundra CV's are a true constant velocity joint not a tripod like on Taco's. They are much stronger! If you have ADD then a set of stock Tundra CV's will plug right in. If you have manual hubs then ORS can make a custom set like the ones we have on our Tacoma.
The only mod that needs to be done either way is trimming the inner CV boot mounting lip off and using a larger diameter heavy-duty boot that will slip over the outside ø of the inner. This will provide the extra articulation needed safely.
Alot of people say that the T100/Tundra A-arms are longer but after looking at a few at the wrecking yard it looks like they are not and the axles are longer because the diff is the same width as a 4runner/pick-up/tacoma, and they need to be longer to mate to the diff?
Thanks
Thanks
914runner is right. Tundra arms are no longer than regular arms, as far as I know. That is why total chaos and jd fab allow for the use of these long travel kits on t-100's as well. When a tundra or t100 gets long travel the axles need to be lengthened.
You can see the difference in the axles on this page; http://www.tundrasolutions.com/photo...2/ppuser/21530
That's a good comparison pic Bruce.
We also have some pics on our website in this article.
CV Article: http://www.trailslesstraveled.com/viewarticle.php?id=41
Sean that T100 body/pickup frame idea is pretty cool. I never thought about that. But would the frame line up with the mounting points on a t100 body? I imagine the t100 frame is wider. Cool concept any-way.
So, to go off my previous question....
For strength purposes only, would it be wise to install Tundra axles into a ADD 4runner? What are the downsides? Would they work w/o installing the long-travel kit?
Why dont people do this more often to their IFS taco's and runners?
Thanks
Grrr...
Okay, I kept on thinking you guys were saying: The Tundra/T100 axles are the same length, and they WERENT longer... But, you were really saying that the ARMS arent longer.
Misunderstanding. It makes sense now to me
RyanJ989
11
Apr 7, 2021 09:41 AM
mistershmi
Jan 5, 2016 11:07 AM
anniesball
12
Sep 30, 2015 08:09 AM
JookUpVandetti
Sep 17, 2015 09:25 PM
