oil filter relocation kit for 3.0?
Hi does any one know where I can find a filter relocation kit for a 3.0. My dad installed one on his 3.4 taco and while he was running his lines he put an inline oil cooler on it and mounted it behind the bumper some where. I want to do the same on my 3.0 to cool the oil, add a little more volume to my oil and make the damn filter easier to get to!!!! If any one knows where I can get one for a good deal let me know! Matt
Seems like Northwest Offroad had a kit at one time.
The Toyota filter has a check valve in it to keep the filter full of oil, so that upon startup, the engine runs less time before the oil system comes to full pressure. If you get a remote kit, make sure thatit has some sort of check valve in it to do the same or you may just be cutting your engine life short by longer dry startups.
Try this : http://www.tdperformance.com/TransDapt.html
There is a dealer locator here as well.
If the filter is mounted vertically you won't have to worry about dry start-ups.
Originally Posted by toy283
You don't need a check valve in the relocation kit but I have considered adding a spring-loaded one in the line.
You're going to use hydraulic hoses to attach the remote filter to the engine and those hoses have a volume that has to be filled up with oil under pressure before it can be sent to the engine.
I'll just keep the stock setup on my engine, use Mobile 1, and change about every 5K. It's worked so far on every vehicle I've owned. I've NEVER worn out a Toy engine...Now VW's are a different story.
I was just looking at one from Performance Products the other day. I was going to ask if anyone had ever done that before. I assume it should be relatively easy to mount a cooler in front of the radiator on my 2nd Gen. Am I way off base on that? Me thinks a good tech write up could be on the way from someone.
When you buy a filter relocation kit it will come with rubber line and barb fittings. Toss that stuff in the junk and purchase some braided line and the correct fittings and adapters for it. Unless you want to replace them every 2 years or so and put up with leaks. Your call on that I guess...
You can click on "my 4Runner" in my sig to go to webshots and look at the filter kit install on my truck. Good luck!
That being the case (and it is most definately tue), it is cheaper to just buy the pieces needed a-la-carte and don't bother with any of the kits. Summit has the block adapter (Trans-Dapt p/n 1013) for $9.88 and the single filter bracket (Trans-Dapt p/n 1028) for $12.75. If you want dual filters, the bracket is quite a bit more; $25.75 (Trans-Dapt p/n 1030). After that all you need is hoses of the length you want and the necessary ends/adapters. For 4-cylinder applications, a #8 hose is usually enough but for V6/8 applications or any application over 4' long I recommend a #10. While a braided stainless setup will cost more initially, the added piece of mind as well as not having to constantly replace them is well worth it in the long run.
I used -8 hose on my 4Runner but they're really short thanks to the place I found to mount the filter bracket. It might be a good idea to use -10 hose if you're running any distance or plumbing in a cooler etc...
I disagree on the checkvalve. The reason there is a check valve on the filter is because it takes a while to fill the filter with a volume of oil, filter it and send it to the engine. The check valve keeps the filter full of oil so that as soon as oil under pressure from the pump hits it, it can begin sending oil to the engine without waiting for the filter to fill up.
XtraCab
Apr 12, 2020 05:25 AM
Sep 4, 2015 09:27 AM
