Inclinometer doesn’t light
Hey guys, i thought it was probably bulbs, but changed them yesterday and it didn’t help.
My speedo lights work. Are inclinometer lights fed from the same circuit?
i can’t find it mentioned in my 86 Toyota service manual or schematics.
YT Community Team
Do you have the EWD manual?
if you do, look under “wiring Routing”
the wire goes from the clinometer down through the hole and plugs into the harness somewhat between the ashtray and heater panel.
The following users liked this post:
Melrose 4r (03-27-2023)
I noticed the switch, but it isn’t the cause. Probably unplugged due to the aftermarket radio that is hacked in. Will have to check when i get to straightening out the radio.
YT Community Team
It'd tied into the light for the heater control panel. Follow that wire and it should take you to where the clinometer wire plugs in
Thanks,Wally. I know the PO had that apart working on the blower fab and heater core. And there is a toggle switch hacked into the middle of the panel above the radio. Suspicious.
edit - took a look; no good way to get a decent photo that would show anything useful. voltmeter should help in terms of finding the wiring for the light circuits.
Tacoma750
10-22-2007 01:27 PM
Fink
14
11-20-2004 02:57 PM
