Power steering fluid
Old Aug 7, 2021 | 08:59 AM
Andy A's Avatar
What version of dexron is everyone using since dexron II is no longer produced?
Old Aug 7, 2021 | 09:37 AM
old87yota's Avatar
I use this stuff:
Toyota part number: 00718-ATF00
I didn't want to mess around with the Dexron / Mercon universal "one fluid fits all" ATF. Sure, they might work just fine, but I know the Toyota ATF/Power steering fluid is compatible.
Toyota has said that Dexron III replaces Dexron II where Dexron II was originally specified.
Old Aug 7, 2021 | 09:53 AM
snippits's Avatar
Walmart Super Tech Dexron 2/3 automatic transmission fluid. Been using it in older GM automatic transmissions too with no problems.
https://www.walmart.com/ip/Super-Tec...ottle/20573820
Old Aug 7, 2021 | 10:13 AM
Andy A's Avatar
thanks much. Finding Even Dex III around here is almost impossible, dex VI no problem.
Power steering is starting to feel heavy and the pump is starting to groan so ordered up a new pump. The old one has been rebuilt once or twice now.
Old Aug 7, 2021 | 10:58 AM
Robert m's Avatar
As long as it's dexron based atf, it will be fine
Old Aug 8, 2021 | 09:35 AM
moto809's Avatar
5 Year Member
Yep. The cap even says "dexron type atf" on mine.
Old Aug 8, 2021 | 01:07 PM
snippits's Avatar
On the back side of the Walmart Super Tech automatic transmission fluid gallon jug.
Old Aug 9, 2021 | 12:07 AM
RAD4Runner's Avatar
Dexron III here, too. Regardless of brand.
Old Aug 9, 2021 | 01:33 PM
MaK92-4RnR's Avatar
Any dexron ATF will work just fine.
Old Aug 9, 2021 | 03:51 PM
wallytoo's Avatar
i believe this implies it isn't forward-compatible; however, it is backwards-compatible. in other words, dex vi is fine in these trucks, but in any vehicle calling for dex vi, dex i/ii/iii are not fine.
simpsons721
Feb 17, 2019 07:44 PM
Tofer
Feb 13, 2011 07:25 AM
Amir904
Feb 12, 2005 07:24 PM
99whiteSR5
Jul 6, 2004 09:20 PM
fourunnabilly
11
Oct 13, 2003 08:39 AM
