Old Apr 20, 2016, 09:09 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
Power Steering Fluid??
Old Oct 10, 2003 | 09:25 AM
fourunnabilly's Avatar
Guest
Hey all-
I relocated my power steering resevoir last night on my 03' 4-Runner with the 4.7L. I refilled it with the same fluid that I drained out of the resevoir and tubes initially, once I had secured the resevoir in its new location. I was definitely low on fluid, but had to drive home for about 15 miles with the fluid low. It was obvious that I was low as my power steering was not working too well. No noises or squeals though. So I ran to Napa this morning to fill my resevoir to the line. On the top of the cap Toyota recommends Dextron ATF for the appropriate fluid when refilling. I bought both the dextron and some valvoline power steering fluid and refilled the resevoir with the valvoline. Within a minute or two, the power steering was back, but the wheels squealed like hell. Once I got home, I popped the hood and was hearing all kinds of noises. So, my questions are this:
Will these noises go away as the fliud gets into the system?
Should I use the Dextron ATF even though it is Automatic Transmission Fluid?
Should I run to the dealership here and buy Toyota fluid??? I think not?
Any help would be much appreciated. Thanks in advance.
Billy
Old Oct 10, 2003 | 09:55 AM
CTB's Avatar
CTB
Re: Power Steering Fluid??
Yes you should...Toyota recommends it for a reason.
Old Oct 10, 2003 | 09:59 AM
Robinhood150's Avatar
Flush your system ASAP and only use the ATF. ATF is standard operating procedure for the newer toyota trucks.
Old Oct 10, 2003 | 10:14 AM
joshik's Avatar
ur supposed to use atf instead of power steering fluid?
i have a 91 yota pu 4x4. i know ppl, including myself, have been talking about their power steering and the problems, and leaks.
is it better to fill with ATF?
Old Oct 10, 2003 | 10:40 AM
Just look at the cap and the manual and it will tell you what to use. Mine say ATF.
Old Oct 10, 2003 | 11:16 AM
Guest
What is the easiest wasy to flush it out? Thanks for all the help.
Billy
Old Oct 10, 2003 | 02:09 PM
Guest
Sorry for my ignorance, but is there something underneath the vehicle that I can unscrew to drain the power steering fluid completely? Or should I just disconnect the hoses at their base and let it run out there? Again, thanks for the help. Just wanna fix it correctly.
Billy
Old Oct 10, 2003 | 02:13 PM
Sorry, I don't know, I've never done it. If you do a search you might find something about it. Try www.4x4wire.com too. However, since yours is so new, I doubt many people have flushed their 4th gen PS pump.
Old Oct 10, 2003 | 02:15 PM
Guest
Thanks Steve. I guess I'll just keep looking.
Billy
Old Oct 11, 2003 | 09:08 PM
Toyo4x4's Avatar
Not exactly a "flush" but a "fluid change process". Buy a turkey baster and remove all the fluid in the reservoir with it and then fill back up with new fluid. Drive around a few days and repeat. One quart should do 3-4 of these procedures. I would do this until you've used about 1.5 quarts and save the rest for top-offs.
Old Oct 11, 2003 | 10:54 PM
kyle_22r's Avatar
i think i might try that. i think the fluid in my PS pump was in there while carter was president it's almost a greenish color
Old Oct 13, 2003 | 08:39 AM
hypnotoad's Avatar
you can empty the PS line this way:
disconnect return line (not the one going to the pump) from the reservoir and route it to a collecting container - a deep one is preferable cause it will sputter and splash!
turn on engine until line runs dry
reconnect everything, fill with new ATF, and check the cold/hot levels for a few days
just did this on my 89 Supra - piece o cake
Zpd426
Jan 2, 2016 01:15 PM
Up&Down
Aug 11, 2015 10:04 AM
gmonnie123
Jul 26, 2015 02:44 PM
yoterr
Jul 24, 2015 04:29 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
