Component Speakers
Old Apr 22, 2004 | 01:39 PM
AmPm's Avatar
Component Speakers
Well, I've just about got the new sound system in place. I decided to go with Kenwood all the way around. 4" Components in the front, 320 watt amp 4ch, Digital EQ. 5 1/2" comps, mono 400 watt amp and sub on the way.
Here is my question...Right inside the back door on the top, there is a light, the wiper motor and 2 1" tweeters. I thought it was interesting since I have never read anything about anyone replacing these speakers. I checked them and they don't work so they are going, but I was wondering if this was a factory thing or if the previous owner had them installed? Oh, I have a '92 runner.
Thanks,
Adam
Old Apr 22, 2004 | 01:51 PM
Astralplane's Avatar
Yes the rear speakers are component.
Old Apr 23, 2004 | 10:00 PM
PAhydrohead's Avatar
I also have a '92 and I think that speakers were only installed in that location if you had the upgraded stereo package with a CD player. I have also thought about installing component tweeters there because it seems that you could aim them to bounce off the windshield right to ear level of the driver/passenger.
Old Apr 23, 2004 | 10:14 PM
Brendan's Avatar
not a fan of kenwood...
anyways, i'm not sure if the 4runners are different, but my truck only has a spot in the front passenger side for a tweeter. the driver's side only has space for the 4" speaker. are they different or is there something i don't know or what?
Old Apr 24, 2004 | 02:08 AM
Krash's Avatar
This is how I mounted my polk components the other day, yeah I know about the wiring showing, I'm working on a solution to that.
Old Apr 24, 2004 | 06:28 AM
Enigma's Avatar
Interesting topic.. as I'm about to get a new HU and a few speakers for my 93. I know some people said the front takes 4T instead of 4".. whats the difference? Will 4" work fine? Is it just a tighter fit or what? Oh.. and I too have wondered about those speakers in the back.. so they are 2", I'm guessing mine work fine cause I know the stock stereo in my runner sounds much better if you are riding in the back than in the front. :/ Gotta do somethin bout that..
Old Apr 24, 2004 | 07:35 AM
It was an option called "premium etr/cass w/ 6 speakers and power antenna" $675.00 back in 1994.
When I replaced my front speakers I used Rockford/Fosgate 4T.
4T stood for Toyota and the speakers only had 2 mouning holes instead of 4.
I don't think they are made anymore. Probably not a big seller.
I looked a replacing the back speakers but a custom bracket would have to be made to mount the tweeters in the stock location.
Old Apr 24, 2004 | 07:40 AM
Enigma's Avatar
So some 4" Should fit then but you only have two mounting holes that you can use? Because yea.. it's hard to find some 4T's nowadays. I looked a bit..
Thanks for the info!
Old Apr 24, 2004 | 09:30 AM
You will have to trim or cut off 2 of the mounting points.
mct75
Aug 22, 2016 01:24 PM
Kamaloha
Oct 16, 2015 05:13 PM
Toys4parts
Sep 26, 2015 01:56 PM
ToyotaMD
Sep 22, 2015 06:28 AM
