Radiator water leak
Radiator water leak
So I have 1995 4Runner with a 3VZE engine. I just recently had the motor installed, it is a used motor with 80,000 miles . Ever since the install the radiator seem to lose all fluid out of radiator. It does not seem to be a head gasket leak. Hose were replaced when engine was installed , also water pump ,timing belt and valve covers replaced before install. All belts replaced also. Radiator was flushed several times to get out anything stuck in radiator. Need advice on where water might be leaking. Can't find location. Going to replace radiator cap also, but does not leak from that area.
Well, a crack in the right place in the head can leak directly to the exhaust as well. If your exhaust system is in good shape (no leaks) it can hold a fair amount of coolant. You will see it, though, as soon as you start. A big white cloud!
skinnyhb
Jul 8, 2008 04:57 PM
